September 02, 2026, 12:37:36 pm
All Things Mk5
Mk5 General Area
R8 coilpacks.....any advantage ?
Topic: R8 coilpacks.....any advantage ? (Read 7552 times)
Dave Y
March 08, 2019, 10:32:09 am »
As above is there any advantage to fitting these ?
i dont know if the ones fitted to my car have ever been changed.
My car has done just over 100,000 miles
MIJ_JAGGER
Won't Shut up.
-Given: 103
-Receive: 79
Re: R8 coilpacks.....any advantage ?
Reply #1 on:
March 08, 2019, 10:45:22 am »
No advantage. Cheaper than black ones though
Dave Y
Reply #2 on:
March 08, 2019, 10:55:56 am »
so i might as well leave well alone
rich83
Just look at my post count
-Given: 165
-Receive: 802
My Ride:
Reply #3 on:
March 08, 2019, 10:59:22 am »
If you coil packs are not causing issues then no reason to change them.
https://www.justgiving.com/thenational3peaks
Dave Y
Reply #4 on:
March 08, 2019, 12:05:01 pm »
i think they are fine but i am having a stage 1 map at Amber performance next week so was wondering if they would be an advantage.
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #5 on:
March 08, 2019, 12:36:25 pm »
You might well find the Stage 1 highlights a weak coilpack and it will misfire afterwards, so be prepared to change them if needed
TFSI... Revo Stage 2+... . WMI.... VCDS HEX + CAN, MPPS, VAG Commander & VAG tacho - South Wales
Dave Y
Reply #6 on:
March 08, 2019, 01:31:49 pm »
perhaps its best to put a brand new set on just in case.
Dave Y
Reply #7 on:
March 08, 2019, 01:57:20 pm »
just ordered a set from AKS tuning £101. inc delivery.
pudding
Global Moderator
-Given: 2
-Receive: 692
Reply #8 on:
March 08, 2019, 02:59:40 pm »
Should probably add a pack of BKR7EIX plugs to the order as well if the ones in there are really old.
Dave Y
Reply #9 on:
March 08, 2019, 04:00:44 pm »
is there anything to be gained from changing the standard air filter ?
There is a Mann filter fitted at the moment.
pudding
Global Moderator
-Given: 2
-Receive: 692
Reply #10 on:
March 08, 2019, 04:10:15 pm »
Not really!
muff1991
Won't Shut up.
-Given: 8
-Receive: 70
Reply #11 on:
March 08, 2019, 04:10:39 pm »
yes, I think a performance filter will aid when mapping. I think its been known to have a better Air filter over an Induction kit.
Dave Y
Reply #12 on:
March 08, 2019, 05:11:06 pm »
What make is known to work well?
Octoparrot
-Given: 8
-Receive: 104
Reply #13 on:
March 08, 2019, 06:32:10 pm »
I'd just bung a new Mann filter in and change it once a year
colesey
-Given: 7
-Receive: 89
Reply #14 on:
March 08, 2019, 06:35:12 pm »
Iirc I read somewhere that the ed30 has a slightly less restrictive panel filter than the k03 car, however something like pipercross or itg will do the job just fine.
All Things Mk5
Mk5 General Area
