September 29, 2026, 04:38:36 am
All Things Mk5
Mk5 General Area
VITO front drop links?
Topic: VITO front drop links? (Read 7952 times)
eb198
Taking part
-Given: 2
-Receive: 1
March 13, 2019, 11:30:30 pm »
Can anyone recommend the correct part number or length people have used when fitting the Mercedes Vito droplinks, or are they from a particular model year? There seems to be several different lengths. The vehicle has been lowered 30mm all round on bilsteins if that makes a difference.
Cheers!
Ed
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 692
Re: VITO front drop links?
Reply #1 on:
March 14, 2019, 08:58:20 am »
Bilstein normally weld the drop link tab in the same position as the standard dampers. You only need shorter ones if you can't get the drop links into the strut with both wheels off the ground.
eb198
Taking part
-Given: 2
-Receive: 1
Reply #2 on:
March 14, 2019, 11:34:30 pm »
Thanks for the reply bro,
But do you have a link for the vito ones at all? Whats the reason for fitting them, they're more durable or stiffer in comparison to standard droplinks? Or are they just shorter?
Cheers!
pudding
Global Moderator
-Given: 2
-Receive: 692
Reply #3 on:
March 15, 2019, 12:18:10 pm »
No idea mate, I use standard ones with my coilovers
All Things Mk5
Mk5 General Area
