Author Topic: Car Cutting Out High Revs  (Read 3239 times)
Offline Tally
« on: April 11, 2019, 02:21:52 pm »
HELP NEEDED.
Any ideas on me mk5 golf gti .
Changed
Coil
Accel pedal
Throttle body
Fault codes
P0222 - Throttle angle sensor
P0123 - throttle position sensor to high
P02122 - accel position sensor to low
P0642 - sensor ref voltage A to low
P0698 - sensor ref voltage to low
It’s ok if I don’t boost it. Once I kick over 3000 revs especially in 3rd / 4thgear it either goes into limp mode, EPC-Enginemanagment and traction control lights come on and I lose power but still drive it OR completely packs in EPC and traction light but no revs undrivable. All I do is disconnect battery then it’s fine 🤔🤔
Please can any1 Advise. I unplugged the MAP Sensor and it was ok for a while, Ran better but its started cutting out again.. Im at my wits end :bang:
Re: Car Cutting Out High Revs
« Reply #1 on: April 12, 2019, 09:54:15 am »
Could be throttle body needs changing.  Quite a common issue on these
Offline Tally
« Reply #2 on: April 12, 2019, 10:33:54 am »
I've already changed it  :sad1:
  • -Receive: 692
« Reply #3 on: April 12, 2019, 03:17:15 pm »
He's changed the pedal and throttle body apparently.
Did you fit new or used parts?  Was the replacement pedal like for like?  I.e. GTI.    For example, a diesel or R32 pedal might not work correctly with a GTI ECU.
I would also check your wiring harness that runs under the vacuum pump and connects to the throttle body.  It's a known problem - https://forums.vwvortex.com/showthread.php?5293518-MKV-GTI-Throttle-body-wiring-harness-repair
It's an EA888 engine in that link as America got that in their 2008+ GTIs, but the same applies to EA113s.
« Last Edit: April 12, 2019, 03:19:27 pm by Pudding »
« Reply #4 on: April 12, 2019, 06:31:35 pm »
Note to self..... read posts properly!  :signLOL:
