Author Topic: Recon rack fitted, problem!  (Read 7331 times)
Offline Rigsby
  • -Given: 22
« on: May 06, 2019, 03:28:03 pm »
Recon steering rack fitted today, on start up I have the orange steering wheel symbol in the dash and no power steering.
Any ideas ?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
Re: Recon rack fitted, problem!
« Reply #1 on: May 06, 2019, 03:51:31 pm »
I had this with a reconditioned mk6 rack only my power steering lasted a day. Have you calibrated it?
Offline Rigsby
  • -Given: 22
« Reply #2 on: May 06, 2019, 04:00:50 pm »
Just sorted it, found a thing on line on how to calibrate it.
Start car
Leave steering wheel cantered for 10 secs
Full left lock 10secs
Full right lock 10secs
Back to centre and light went off
On the bad side I still have knocking steering 🤬
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
« Reply #3 on: May 06, 2019, 04:08:21 pm »
Again, same here. Right pain in the hole.
Offline Rigsby
  • -Given: 22
« Reply #4 on: May 06, 2019, 07:34:04 pm »
Have you still got the rack on? Where did you get it from?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
« Reply #5 on: May 06, 2019, 08:10:10 pm »
I swapped back to my original mk5 rack. I got mine from bb reman on eBay.
Offline Rigsby
  • -Given: 22
« Reply #6 on: May 06, 2019, 08:16:12 pm »
Christ!!! A lot of labour to end up back where you started
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
« Reply #7 on: May 06, 2019, 08:30:42 pm »
Yep. When the mk6 rack was in the steering did feel really, until it failed.
Offline Rigsby
  • -Given: 22
« Reply #8 on: May 07, 2019, 10:42:37 am »
I’m starting to think this noise is my H&R springs? 🤷🏻‍♂️
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #9 on: May 07, 2019, 10:56:46 am »
How can springs cause a noise?
The racks are prone to making some awful noises even with little to no discernible play. Other causes can include the common subframe creaking
Offline Rigsby
  • -Given: 22
« Reply #10 on: May 07, 2019, 12:48:29 pm »
Binding, coils , that’s why some come with insulators.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
« Reply #11 on: May 07, 2019, 01:34:12 pm »
I solved my issue by changing pads, even though the pads I took out were only a few months old.
  • -Receive: 692
« Reply #12 on: May 07, 2019, 03:31:05 pm »
Bump stops kick in way before springs go coil bound.  It's one of the first things reputable brands like H&R check when making lowering springs for OEM dampers.
Offline Rigsby
  • -Given: 22
« Reply #13 on: May 10, 2019, 11:35:33 am »
Hmmm, thinking about it it doesn’t make the noise when the car is stood , full lock to lock no noise. Only when the car starts creeping slowly and turning I get click/knocking noise, faulty cv joint then?
Offline muff1991
  • -Receive: 70
« Reply #14 on: May 13, 2019, 09:04:09 am »
sounds like it could be the CV joint then yeah. My mate had a creaking on his steering once and it turned out to be the bolts clamping the rack to the sub frame wasn't tight enough! but that was doing it moving and stationary. if yours is only moving, then could well be the CV joint. find an empty car park and drive round in circles (full lock left and right) while listening for that click!
A mate also had a clicking sound once. And the drive shaft bolt (centre hub bolt) wasn't tight enough.
