Author Topic: Broken sensor  (Read 1467 times)
Offline Stefanwalker14
Broken sensor
« on: May 19, 2019, 03:17:35 pm »
Just seen that this sensor looks to be broken, is that normal or does it need replacing and what does it do?
Re: Broken sensor
« Reply #1 on: May 19, 2019, 06:41:11 pm »
It’s the camshaft adjustment sensor.
Re: Broken sensor
« Reply #2 on: May 19, 2019, 07:23:48 pm »
@rich83 thank you mate, I’ve had a read up about it. Obviously the N205 needs replacing but would the connector that plugs into still be okay or would that need changing too? Sorry for the incompetence just new to all this!
Re: Broken sensor
« Reply #3 on: May 20, 2019, 12:29:12 am »
The actual look connector looks ok so you would just need the sensor.
Offline muff1991
  • -Receive: 70
Re: Broken sensor
« Reply #4 on: May 23, 2019, 10:23:37 pm »
Yes, just replace sensor. This happened on mine! I think it’s quite common for the sensor connector to break! Just extract the old sensor from the connector plug and fit a new sensor.
