Author Topic: Help identifying fault code - 08328 DTC not found  (Read 4475 times)
Offline Broomy
  • -Given: 18
« on: September 16, 2019, 09:13:50 am »
Appealing to the masses with this one as I’ve had no joy scouting the web for clues.
Fitted a new battery last week & had one trouble free trip afterwards before the EML came on & left the following 2 codes
01681 abs wheel speed signal (rear left) sporadic lower limit exceeded
08328 - DTC not found
I’m going to try cleaning up the rear left sensor & ring later today see if that clears the first code.
Can anyone help with the 2nd one? Very rare you get zero hits on google for something, it really has me stumped  :doh:
If I clear the codes I can continue my journey & usually one more but the next time I start the car the EML illuminates & doesn’t go off until cleared again.
Anyone?
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Help identifying fault code - 08328 DTC not found
« Reply #1 on: September 17, 2019, 03:04:52 am »
What are you scanning the car with? Might need a VAG specific tool such as VCDS or OBDeleven.
Agree that its odd not to find a hit on Google!
Offline Broomy
  • -Given: 18
« Reply #2 on: September 17, 2019, 08:17:52 am »
Using an Autel Vag405 scan tool but you’re right may need to see someone with vagcom or vcds.
Offline doylebros
  • -Receive: 310
« Reply #3 on: September 17, 2019, 07:42:04 pm »
 Possibility it's just a random code but put P in front and errors exist
http://p0832.obdcodes.me/volkswagen-sportvan
Offline Broomy
  • -Given: 18
« Reply #4 on: September 17, 2019, 08:46:44 pm »
Hmm... that code seems to suggest ‘clutch pedal switch A circuit high’ & from reading suggests jumpy revs as a symptom which I don’t have.
Can I ask why you thought to put P in front? Just for my own curiosity.
Will just bite the bullet & leave it to the mechanic to sort as I’m clutching at straws.
Offline doylebros
  • -Receive: 310
« Reply #5 on: September 17, 2019, 09:08:49 pm »
It's not uncommon for VW fault codes to be pre-fixed with the letter P
Offline Broomy
  • -Given: 18
« Reply #6 on: September 17, 2019, 09:24:01 pm »
Ah I see. Why would the last 8 fall off the original code?
