Author Topic: Rear Brake Disc Shield  (Read 6708 times)
Offline pandaman
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115571.0.html
« on: December 19, 2020, 08:21:45 pm »
Had a go at replacing a rear bearing recently and whilst at it found the brake dust shield hanging on by a thread around the 3 bolts.
Broke off completely with very little force whereas the bolts did not. Decided not to replace at the time, didn't want to bugger up the 3 bolt heads, i was losing light and euro car parts is about half an hour away.
Surprisingly, only a few days later the other side came loose, it sounded like the exhaust had fallen off! Jacked it up, tin snipped the thin connecting part and yanked it off.
Googling a few posts on here, some say they're not completely necessary and to replace them i'd have to take off the bearings.
Anyone else running without them? whats the worst i could expect not replacing them?
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Rear Brake Disc Shield
« Reply #1 on: December 19, 2020, 08:51:38 pm »
Just had a pair on mine, they're £27 each + vat from TPS genuine parts, yes the hubs and brake carriers need removing to fit them.
Many people just leave them off, I left them off on my mk2 Golf. Only thing I can see would be more corrosion on inner disc as no guard to stop the puddles splashing on the inner egde of disc?  :thinking:
  • -Receive: 692
« Reply #2 on: December 19, 2020, 09:46:57 pm »
VW put them there for a reason.  If you don't know what the consequences of removing them are, it's probably better to leave them in place?
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #3 on: December 19, 2020, 10:09:39 pm »
That was my thinking tbh.  :laugh:
Offline terrier
  • -Receive: 41
  • My Ride: GTI now gone
« Reply #4 on: December 20, 2020, 08:05:02 am »
cutting the flat section off will help but dont leave any exposed metal :happy2:
« Reply #5 on: December 20, 2020, 05:04:25 pm »
I ran my car for about a year maybe longer with no rear shields. Not ideal but no ill effects. I figured I was going to wait to do the rear bearings and shields all at the same time. I still don't have shields on the front.
The screws can be a bugger to get off. If you have trouble, then driving them around with a punch and hammer should work.
Offline Octoparrot
  • -Receive: 104
« Reply #6 on: December 20, 2020, 07:09:51 pm »
I did this with mine with no ill effects.
Offline LC5F
  • -Receive: 80
« Reply #7 on: December 20, 2020, 08:59:40 pm »
I'm running aftermarket galvanised pressed steel ones that should be a lot less susceptible to rust.
When I converted to Scirocco alloy hubs I had to remove bearings from 2 sets of rear hubs, all 4 times the bearings came off by hand without puller or any fuss - the inner race did not separate, so no damage
Personally, its a lot more work, but I would just dive in and take off the bearing... but the nightmare I had was the caliper carrier bolts.
