Author Topic: Mk5 GTI Carbonio Panel Filter Replacement  (Read 1946 times)
Offline Greenman
  • Life is not a straight line!
« on: January 31, 2021, 02:17:50 pm »
Hi all.
I need to replace the panel filter in my Carbonio Intake as it is starting to split etc.
I don't think i have an APR Carbonio as it looks different to some APR ones i have seen on mk5 GTI's and has no APR sticker. Will go and take a picture of it in a minute.
Do you know where i can just source the panel filters alone rather than having to buy a whole Inatke?
TIA.
G.
« Last Edit: January 31, 2021, 02:19:25 pm by Greenman »
Steel Grey 2006 Mk5 GTI - R-TECH Stage 1 (268bhp/334ftlb) - BCS Cat Back - Pre-Cat Delete - Carbonio Panel Filter - Rev G DV - 18" BBS CH - Leather - RNS510 - Colour Coded Bumpers and Skirts - ED30 Front Splitter - Eibach Sportlines - Open Fog Grilles - Wind Deflectors.
Offline colesey
  • -Receive: 89
Re: Mk5 GTI Carbonio Panel Filter Replacement
« Reply #1 on: January 31, 2021, 05:22:44 pm »
Slightly off topic but do you have a dyno chart you can post here from Rtec? I was impressed by the figures in your signature.
Offline Greenman
« Reply #2 on: January 31, 2021, 08:42:56 pm »
In have somewhere will need to look it out was a few years ago
Offline Greenman
« Reply #3 on: February 04, 2021, 08:27:13 pm »
Can anyone help?
« Reply #4 on: February 04, 2021, 09:13:00 pm »
The carbonio type intake uses the standard airbox so just replace it with a standard filter.
Offline Greenman
« Reply #5 on: February 10, 2021, 02:33:32 pm »
Great thanks.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #6 on: February 10, 2021, 05:35:48 pm »
The APR Carbonio is just a carbon air inlet scoop.
The OE filter remains inside the engine cover.
Here is a vid showing how to replace it.
Just be more careful when removing it and replacing the engine cover/air box. Many times, people damage or crack the fuel pressure regulator on top of the HPFP when fooling around with the engine cover. I cringed when he set the engine cover on top of it in the vid...because this can happen:
« Last Edit: February 10, 2021, 05:39:20 pm by ROH ECHT »
