Author Topic: Starting issues, cranks no start?  (Read 13106 times)
Offline DBXdarkangel
  • -Given: 18
Re: Starting issues, cranks no start?
« Reply #30 on: March 27, 2021, 04:54:41 pm »
How much did you pay for the car?
Offline Vsandhu15
« Reply #31 on: March 27, 2021, 07:36:51 pm »
Paid £800 for it from a mates cousin. But had seen videos of it running engine is sweet sounds great and car drives in all gears except reverse and fourth. Its a 2007 black 5 door manual
Offline LC5F
  • -Receive: 80
« Reply #32 on: March 27, 2021, 08:38:09 pm »
Good to hear you got to the bottom of this.
If the gears wont select at the gearbox with cables disconnected it suggests something is wrong inside the box - this could be the cause of the timing being out.
Options are:
Rebuild current box - but likely you will need replacement parts and rebuild cost is expensive, but you get peace of mind.
Swap out for a good used one - lots out there, recently Pudding swapped his out for a Mk6 box,   iirc he said the box was £260 reports better ratios and improved gear selection and they tend to have lower mileage than Mk5's
