Author Topic: Front indicator bulb help  (Read 1890 times)
Offline Jons1001
  • -Given: 22
« on: April 26, 2021, 03:05:46 pm »
Firstly I'll apologise for being an idiot but trying to change the driver's side front indicator bulb and I can't find it! YouTube says its a simple twist and pull tab that should be visible straight away and another website says it's under the inner most circular cap.
Inside inner cap
Offline brian_badonde
Re: Front indicator bulb help
« Reply #1 on: April 26, 2021, 03:19:25 pm »
There's another plastic insert below the main beam cover:
Turn this 90 degrees counterclockwise and pull it out to get to the indicator bulb.
Offline Jons1001
  • -Given: 22
« Reply #2 on: April 26, 2021, 03:22:07 pm »
Thanks mate
Offline Jons1001
  • -Given: 22
« Reply #3 on: April 26, 2021, 08:12:08 pm »
I still can't find it!  :laugh:
Here's the two caps I can see, and can't see/feel anything under either.
But here is another cap which looks like it houses the xenon bulb?
Again can't see/feel anything underneath. This is very tight aswell can't really get under it.
Offline akbarirfan
  • -Given: 81
« Reply #4 on: April 29, 2021, 11:14:10 am »
I think it's in the middle of you last pic in the first post.
