October 17, 2026, 10:26:43 pm
All Things Mk5
Mk5 General Area
Aerial rubber replace / Aerial removal
Topic: Aerial rubber replace / Aerial removal (Read 2072 times)
Trav Turbo
Always Involved
-Given: 18
-Receive: 3
May 25, 2021, 10:51:43 am »
Hello all! Has anyone replaced a Aerial base rubber on a 3 door GTi before & know where the aerial wire is located under the headlining & trims to undo the wire to remove the aerial?
Thanks in advance.
Sent from my SM-N950F using Tapatalk
bobby_fodge
Won't Shut up.
-Given: 22
-Receive: 39
Re: Aerial rubber replace / Aerial removal
Reply #1 on:
May 25, 2021, 11:13:14 am »
if you put the rubber aerial base in warm water for a while it become soft enough to slip over the aerial base without removing it.
Trav Turbo
Always Involved
-Given: 18
-Receive: 3
Reply #2 on:
May 25, 2021, 11:20:46 am »
Amazing! Thanks for your help cheers
imprezzaworks
Always Involved
-Given: 10
-Receive: 6
Reply #3 on:
May 25, 2021, 08:34:23 pm »
As above that's how I did mine
Lewo
Won't Shut up.
-Given: 8
-Receive: 35
Reply #4 on:
May 25, 2021, 08:57:34 pm »
Need to do mine as it goes, Ebay for the rubber base?
imprezzaworks
Always Involved
-Given: 10
-Receive: 6
Reply #5 on:
May 25, 2021, 09:02:03 pm »
Yeah. There about a fiver iirc
All Things Mk5
Mk5 General Area
