Author Topic: Air con help  (Read 9237 times)
Offline Jons1001
  • -Given: 22
Air con help
« on: June 07, 2021, 04:00:00 pm »
Hi everyone,
Any ideas what could be the problem with my air con?
Only blowing warm, clutch is engaging and the bolt in the middle is spinning with it. Fan isn't starting though. Been to Kwik fit and the car has no leaks according to them and is holding gas. Here is some info. From obdeleven...
So going from above its saying the compressor is rotating but possibly not getting the current it requires? Or am I reading that bit wrong. Thanks
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Air con help
« Reply #1 on: June 07, 2021, 08:57:31 pm »
Code 16 not activating.
I know the high-pressure switch is common on mk5s.
Is there any fault codes in hvac?
https://euroautotraining.com/blog/late-model-vw-ac-compressor-shut-codes
16 = Compressor off (activation A/C Compressor Regulator Valve -N280- implausible)
N280 fault maybe then?
Available on Autodoc.
« Last Edit: June 07, 2021, 09:18:03 pm by GVK »
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #2 on: June 07, 2021, 09:19:35 pm »
Thanks, is there a way of testing the n280? Also I did have my thermostat changed around the time this happened, now wondering if this could have been disturbed/left unplugged etc.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Air con help
« Reply #3 on: June 07, 2021, 09:26:17 pm »
Don't know, I've only just learnt what a N280 is!  :grin:
« Last Edit: June 07, 2021, 09:28:07 pm by GVK »
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #4 on: June 07, 2021, 09:42:17 pm »
Haha fair enough  :happy2:
Will do some investigating...
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #5 on: June 11, 2021, 04:12:56 pm »
So, local Kwik fit have kindly offered to degas the system free of charge. Does anyone know how easy it is access/remove the solenoid on our cars? (Mine is 2008 standard gti).
Offline FJB
Re: Air con help
« Reply #6 on: June 11, 2021, 05:52:34 pm »
I had to remove the compressor to replace my valve. Pretty easy once the compressor is off, and you will need some circlip pliers.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #7 on: June 11, 2021, 07:13:59 pm »
Ah so you do have to fully remove the compressor in order to change the solenoid valve? Was hoping I could just get under and remove it on its own   :scared:
Offline FJB
Re: Air con help
« Reply #8 on: June 11, 2021, 07:30:13 pm »
You probably can but it is very tight for space.
  • -Receive: 692
Re: Air con help
« Reply #9 on: June 11, 2021, 10:46:13 pm »
As per GVK, I'd start with the pressure switch as it's very common, and also the cheapest/easiest starting point.......even though said sensor is about 70 quid from VW!
Can you remember what the A/C was like before it broke though?  Even when fully operational it's pretty lame and inefficient  :grin:
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Air con help
« Reply #10 on: June 11, 2021, 10:59:10 pm »
Fault mode 16 points to the N280 being faulty or not being activated, which can be the pressure switch.
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #11 on: June 12, 2021, 02:06:42 am »
Decisions  :thinking:. It's working out about the same price to change either the pressure switch or the solenoid.
Pressure switch £70
Solenoid £20 plus regas £50
Assuming I can change both myself. Any ideas on what the most likely culprit is bearing in mind the shut off code I have? Or would the fact the compressor is not getting the correct current/fan not working point us to either the pressure switch or solenoid?
« Last Edit: June 12, 2021, 07:29:18 am by Jons1001 »
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Air con help
« Reply #12 on: June 12, 2021, 08:54:44 am »
Kwik Fit gained precious gas when they removed your AC gas. If they’re charging fully for a gas recharge, they’re making money twice from you. They should just charge you for the labour involved in that.
I’d replace the solenoid first. Good luck!
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #13 on: June 12, 2021, 09:23:40 am »
Hi, initially I took the car to Kwik fit for a recharge to see if that would solve the issue. It didn't and they didn't charge me anything, so at present I have a fully charged non working system. They said they will remove the gas free of charge (haven't yet) and they I just rebook for a recharge when I've fitted new pressure switch/solenoid. So only paying for one recharge which is pretty fair of them.
Thinking now is buy a cheap pressure switch £15 and try that first as easier to fit myself. If not then buy solenoid, get gas removed, fit solenoid (looks a pain and possibly have to remove compressor), recharge gas and hope that does the trick.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Air con help
« Reply #14 on: June 12, 2021, 12:15:03 pm »
You need to remove the gas to replace the pressure sensor too.
