Author Topic: Air con help  (Read 9236 times)
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #15 on: June 12, 2021, 12:56:03 pm »
You need to remove the gas to replace the pressure sensor too.
Thanks, most other forum posts I have read say otherwise though? Unless the pressure sensor has failed at the seal so is leaking gas.
Anyone clarify?
Offline FJB
Re: Air con help
« Reply #16 on: June 12, 2021, 01:18:48 pm »
You do not have to remove the gas, the sensor is screwed onto a self sealing valve when removed. Just remove and replace, no gas will escape!
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Air con help
« Reply #17 on: June 12, 2021, 02:04:37 pm »
Oh, I didn’t know that. When I had mine replaced I didn’t see the valve. Thanks for clarifying.  :happy2:
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Air con help
« Reply #18 on: June 12, 2021, 02:55:03 pm »
I thought that the pressure switch was on like a schrader valve so you can undo the switch and the gas doesn't escape - maybe wrong been 10 yrs since I did one at least. lol.
Offline maxamplitude10
  • '07' ED30 Manual 3Dr
Re: Air con help
« Reply #19 on: June 16, 2021, 08:03:36 am »
Hi does anyone have the VW part numbers for the 2 components mentioned?
Max
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Air con help
« Reply #20 on: June 16, 2021, 08:26:51 am »
I searched for a 2008 car - 1K0 959 126 A VAG Pressure Switch, air conditioning number 18 here
https://volkswagen.7zap.com/en/rdw/golf+variant+4motion/golf/2008-625/2/260-260041/#18
It appears that the N280 is part of the compressor, can't see it listed seperatley, but can get it from Autodoc aftermarket.
« Last Edit: June 16, 2021, 08:28:30 am by GVK »
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #21 on: June 16, 2021, 09:25:38 am »
I've got the pressure switch coming any day now so will let you know if this solves it for me. If not gona buy the solenoid.
Offline nicolacam
  • Newbie
Re: Air con help
« Reply #22 on: August 03, 2021, 03:57:23 pm »
Fixing stuff like this is a nightmare.
Offline wertyhas
Re: Air con help
« Reply #23 on: January 10, 2022, 09:33:53 am »
I still can't fix this.
Re: Air con help
« Reply #24 on: January 22, 2022, 05:21:55 pm »
Code 16 not activating.
I know the high-pressure switch is common on mk5s.
Is there any fault codes in hvac?
https://euroautotraining.com/blog/late-model-vw-ac-compressor-shut-codes
16 = Compressor off (activation A/C Compressor Regulator Valve -N280- implausible)
N280 fault maybe then?
Thanks, is there a way of testing the n280? Also I did have my thermostat changed around the time this happened, now wondering if this could have been disturbed/left unplugged etc.
This is very interesting as my Air-con decided to stop cooling at the same tine I changed the thermostat too, I wonder if there is a sensor/wire or similar been disturbed??
Re: Air con help
« Reply #25 on: January 22, 2022, 05:25:35 pm »
Did this solve your issue?
Offline Jons1001
  • -Given: 22
Re: Air con help
« Reply #26 on: January 23, 2022, 08:51:22 am »
Hi, very sorry I never updated . Turned out in my case I was lucky as when I got under the car to fit an ac solenoid valve (pressure sensor didn't solve it and is fitted from above but reading on you'll see why it didnt solve it) I noticed the sensor for the solenoid had been left unplugged by the mechanic who fitted the thermostat a few weeks earlier! So this was why my ac wasn't working all along!
I have got a pressure sensor, the crows foot spanner needed to fit it and an ac solenoid valve you could have for a reasonable price though now if you're interested.
Edit: just noticed you had your thermostat changed too, get under and have a look. Mine was very obvious as the sensor was just hanging there disconnected.
« Last Edit: January 23, 2022, 08:55:37 am by Jons1001 »
Re: Air con help
« Reply #27 on: January 23, 2022, 06:47:49 pm »
Ah ok I'll have a poke around in that case and see what I can find?
