Author Topic: MAF Sensor part number help  (Read 4380 times)
Offline Jons1001
  • -Given: 22
« on: June 09, 2021, 01:01:14 pm »
Hi,
Got an error code with the MAF sensor, I've tried cleaning it but its not going away. Does anyone know what the correct part number is please?
Offline Sebas_theFish
Re: MAF Sensor part number help
« Reply #1 on: June 09, 2021, 01:03:16 pm »
FSI- 06F906461A
TSI- 06J906461B
« Last Edit: June 09, 2021, 01:18:58 pm by Sebas_theFish »
Offline Jons1001
  • -Given: 22
« Reply #2 on: June 09, 2021, 03:19:13 pm »
FSI- 06F906461A
TSI- 06J906461B
Thanks mate.
£142 AKS Tuning (Genuine)
vs
£35 Just German Parts
Hmmm
  • -Receive: 692
« Reply #3 on: June 11, 2021, 11:26:07 pm »
Hmmm indeed.  The £35 one will 100,000% be a Chinese knock off.  It's the engine's primary load sensor, not worth the risk.
If £142 is too much to stomach, the next best thing is the Hitachi one from CarParts4Less (EuroCarParts sister company) for £110.  Hitachi were the original OEM supplier and you won't go wrong with that.
https://www.carparts4less.co.uk/search/434440970?gclid=Cj0KCQjwk4yGBhDQARIsACGfAeuFRuVVDnxWSBRcN-3WJIBG316sNfm5o0Ig0orPMN7paf-ePoIAelAaAq4HEALw_wcB
Ignore the 'Huco' or whatever label on it, it is the proper part.  Hitachi keep rebranding themselves.  They're a good brand. The genuine MAF and that Huco Boss one are both made in the UK, it's the same thing  :happy2:
What is the fault code?  Don't waste your time cleaning a MAF, it does absolutely diddly squat.  If it's anything like "Short to Ground", "Short to B+" or "implausible signal - intermittent", bin it.  They just wear out over time.
If unplugging it with the engine running does nothing, it's definitely dead.  Another check is with a scan tool on live data.  If the MAF reading is too low (less than 2g/s at hot idle) or it doesn't move, it's dead.
« Last Edit: June 11, 2021, 11:36:11 pm by Pudding »
Offline Jons1001
  • -Given: 22
« Reply #4 on: June 12, 2021, 02:10:11 am »
Cheers Pudding, although the £35 sensor arrived yesterday and is already on the car  :laugh: :scared:
It did immediately clear the fault code, however are you saying it could cause damage, or just likely to fail quickly? Thanks
  • -Receive: 692
« Reply #5 on: June 26, 2021, 03:03:23 am »
Fair enough chap  :happy2:
It shouldn't cause damage, but it will likely fail far sooner than an OEM one. The calibration could also be questionable.  Keep an eye on the long and short term trims if you have a scan tool/VCDS  :happy2:
5-6 years is a good life span for an OEM MAF.  A Chinese one, who knows!  If it lasts a year I'd be surprised, but if it gets you out of a hole in the short term, just roll with it  :happy2:
Offline Jons1001
  • -Given: 22
« Reply #6 on: June 26, 2021, 06:42:09 am »
Why didn't I listen?! It failed after just 3 days throwing a code relating to the MAF sensor and a new one related to fuel trims  :scared:
I've now bought and fitted the Hitachi one as I got a deal on one for £60. Early days but I did a 300 mile drive yesterday and no codes yet so fingers crossed it will see me right.
  • -Receive: 692
« Reply #7 on: June 30, 2021, 10:44:54 pm »
3 days!  That is a quick death even for a Chinese one!
Never mind fella, you live and learn, £95 for both of them is still £45 cheaper than a new one from VW  :happy2:
The problem with Chinese sensors is they aren't calibrated and tested like the oem/oem equivalent ones are.  They just copy what they can see physically, but don't necessarily understand the inner workings.  The MAF might seem like a simple piece of plastic externally, but inside it is a very complicated and finely tuned electronic circuit, which the engine totally relies on to run properly  :smiley:
Offline burtz
« Reply #8 on: December 07, 2022, 01:27:25 pm »
Sorry for bumping an old thread
I need to replace my MAF sensor and found this on CarParts4Less
https://www.carparts4less.co.uk/p/hitachi-air-mass-sensor-air-flow-meter-434440940
£144 seem expensive. Is this the correct one?
I did find this from a website i haven't used before https://www.onlinecarparts.co.uk/hitachi-3229328.html
  • -Receive: 692
« Reply #9 on: December 09, 2022, 08:48:18 pm »
Yeah that's the right one.  Hitachi do make them for VW, and also the High Pressure Fuel pump, so don't be put off by the brand if you're not familiar with it.
If you want peace of mind, for an extra tenner you can get a legit one - https://www.akstuning.co.uk/shop/home/1108-genuine-vag-mass-air-flow-maf-sensor-tfsi-platform-06f906461a.html
EuroCarParts and CarParts4Less (same company) are not discounting currently, due to the state of the world, so shop around.
Offline burtz
« Reply #10 on: January 03, 2023, 01:42:18 pm »
Thanks Pudding!
CP4L are doing the Hitachi one for £120 now with a discount code  :happy2:
