Author Topic: Fuse info help  (Read 2182 times)
Offline Jons1001
  • -Given: 22
Fuse info help
« on: June 18, 2021, 05:05:25 pm »
Hi looking for some urgent help if possible. I have a 2008 dsg gti (BWA) and looking for the correct fuse list as there are so many online. Basically I've replaced the ac pressure sensor and also replaced a 10a fuse that looked blown thinking it may be the AC fuse. Now I have loads of as faults and the climatronic has packed up altogether, also a 'oil sensor garage' has appeared on the dash and won't clear. Please tell me these are somehow linked! Any help much appreciated.
« Last Edit: June 18, 2021, 05:09:18 pm by Jons1001 »
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Fuse info help
« Reply #1 on: June 18, 2021, 05:23:34 pm »
If no one else replies I can see if it gives fuse info in my owners manual for you.
Mine's an Edition 30 but also a 2008 car.
It's pouring of rain atm here!
Offline Jons1001
  • -Given: 22
Re: Fuse info help
« Reply #2 on: June 18, 2021, 05:52:58 pm »
Thanks mate only if the rain dies down. Well the pressure sensor was pissing out gas so gona put the old one back in for now. But not sure on the oil warning.
Offline Jons1001
  • -Given: 22
Re: Fuse info help
« Reply #3 on: June 18, 2021, 07:59:17 pm »
Sorted now thanks. Fuse 4 (5a) had blown. Upon replacing fans working again and oil sensor message gone from dash?!!
Quest for cold air con continues though :-(
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Fuse info help
« Reply #4 on: June 18, 2021, 09:04:40 pm »
Did you say the new pressure switch leaked?
Offline Jons1001
  • -Given: 22
Re: Fuse info help
« Reply #5 on: June 18, 2021, 09:17:33 pm »
Yes mate. But think we have made a cock up....when we took out the old switch there was no o ring, fitted the new one with o ring and that's when the codes came and climate shut down etc.
When I lifted the bonnet you could hear gas escaping. Fitted the old switch without o ring (as that's how it came off) but with hindsight we reckon the old o ring was still in so we put one on top of the other if you get what I mean, and it didn't seal properly!
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Fuse info help
« Reply #6 on: June 18, 2021, 09:21:13 pm »
Sounds about right.  :phew:
