Author Topic: Turning to build pressure following oil change but not starting.  (Read 2717 times)
Offline andyiseddy02
  • My Ride: 2006 Passat SEL estate. 2.0 FSI T.
Is there any way of turning the engine over without it starting to get the oil flowing following an oil and filter change.
With an older car it would be a simple case of pulling the HT lead out of the cap.
Offline Jb55
Re: Turning to build pressure following oil change but not starting.
« Reply #1 on: July 19, 2021, 09:17:54 pm »
Pull the fuel pump fuse
Offline LC5F
  • -Receive: 80
« Reply #2 on: July 19, 2021, 11:33:18 pm »
or unclip the loom from the coil packs
« Reply #3 on: July 20, 2021, 11:26:00 am »
Not sure why you would want to do that. It takes about 1-2 seconds for the pressure to build back up after a change. No big deal.
« Reply #4 on: July 20, 2021, 06:58:15 pm »
Sounds like a sensible idea to me. Those couple of seconds without oil circulating puts extra wear on an already high mileage engine.
« Reply #5 on: July 21, 2021, 12:18:31 pm »
Negligible.
Offline LC5F
  • -Receive: 80
« Reply #6 on: July 21, 2021, 02:34:47 pm »
In day to day use, I agree negligible
But if the engine is freshly built or has stood for a very long while with all the oil in the sump, getting the oil pressure up before firing is has to be a good thing.
Unfortunately the detail of why the OP wants to do this has been missed out.
« Reply #7 on: July 23, 2021, 06:30:51 am »
Reason?
Do I have to give a reason other than it is something I want to do.
Offline DBXdarkangel
  • -Given: 18
« Reply #8 on: July 23, 2021, 03:03:56 pm »
Gonna get cold in here with that attitude I reckon.   :thinking:
  • -Receive: 692
« Reply #9 on: July 24, 2021, 01:26:53 am »
There are anti-drain back check valves in the block and oil pump to make post oil change priming unnecessary.
If you want to do it though, I recommend removing the spark plugs as the engine will turn over faster and therefore build oil pressure quicker.
