Author Topic: CEL Runner flaps  (Read 1408 times)
Offline colesey
  • -Receive: 90
CEL Runner flaps
« on: April 05, 2022, 02:51:33 pm »
I just had a CEL pop up with error codes P3193 and P0642 relating to the runner flap motor. Are there any common issues here? I am wondering if this might be related to a physical blockage (ie carbon clean needed) or a simple electronic issue eg corroded wiring / bad sensor. (I did try a search but the function isn’t working). Fwiw I managed to clear the light without it coming back (yet...) and the car drives well.
« Last Edit: April 05, 2022, 05:56:15 pm by colesey »
Offline GVK
  • -Receive: 77
    • GVKmotorsport
Re: CEL Runner flaps
« Reply #1 on: April 05, 2022, 09:06:56 pm »
Google the codes and add ross tech wiki to your search, I've heard of the motors getting stuck before,
http://wiki.ross-tech.com/wiki/index.php/19649/P3193/012691
http://wiki.ross-tech.com/wiki/index.php/17026/P0642/001602
Chceck out special notes on there.
I did have similar codes once when I had my ED30, but they only came up once and didn't return.
« Last Edit: April 05, 2022, 09:14:16 pm by GVK »
Offline colesey
  • -Receive: 90
« Reply #2 on: April 06, 2022, 10:41:12 am »
Thanks @GVK, I had already googled those but was wondering whether there was a commonly known cause rather than a list of potential issues. Since both your light and mine reset fine, I won’t worry about it too much but will have it investigated when I get an inlet clean done later this year.
Offline GVK
  • -Receive: 77
    • GVKmotorsport
« Reply #3 on: April 06, 2022, 07:34:23 pm »
Be an ideal time to change the motor if you're having an inlet clean as I believe it's a right pain to change the motor in situ.
