September 23, 2026, 09:10:20 am
All Things Mk5
Mk5 General Area
Brake issues
Topic: Brake issues (Read 2593 times)
NorthWest
Just Arrived
-Given: 0
-Receive: 0
2007 GTI
Brake issues
April 07, 2022, 07:09:44 pm »
So replaced both side front pads and discs . Drivers side disc getting very hot . Replaced the caliper with brand new one as guessed that was the issue as torn booth on it .
-just after a spin with new caliper and bleed done and it’s still getting very hot compared to the passenger side ? I am completely lost now ?
Any ideas ? Maybe it’s just the new pads ?
DBXdarkangel
Always Involved
-Given: 18
-Receive: 9
Re: Brake issues
Reply #1 on:
April 07, 2022, 07:42:32 pm »
Was it a genuine Branded caliper of some ebay jobby that was spray painted not powder coated?
NorthWest
Just Arrived
-Given: 0
-Receive: 0
2007 GTI
Re: Brake issues
Reply #2 on:
April 07, 2022, 07:52:56 pm »
No genuine caliper mate brand new
FatWelshBoy
Always Involved
-Given: 2
-Receive: 6
Re: Brake issues
Reply #3 on:
April 07, 2022, 08:36:13 pm »
Brake hose in good condition?
NorthWest
Just Arrived
-Given: 0
-Receive: 0
2007 GTI
Re: Brake issues
Reply #4 on:
April 07, 2022, 08:48:26 pm »
yep all looks good man. not sure what else to trouble shoot from here ?
ald1717
Always Involved
-Given: 17
-Receive: 4
My Ride:
Re: Brake issues
Reply #5 on:
April 07, 2022, 09:50:19 pm »
is it braking straight or does it pull to one side?
G-olf
Always Involved
-Given: 2
-Receive: 5
Re: Brake issues
Reply #6 on:
April 07, 2022, 10:20:14 pm »
Assuming everything with caliper is ok, wheel bearing??
NorthWest
Just Arrived
-Given: 0
-Receive: 0
2007 GTI
Re: Brake issues
Reply #7 on:
April 07, 2022, 11:03:30 pm »
No noise with wheel bearing anyways . I’ll pull caliper back off tomorrow and re check …all I can think of doing now is putting old pads back on (still loads of life) and see if the binding stops
Flyingscotsman
Always Involved
-Given: 26
-Receive: 23
Re: Brake issues
Reply #8 on:
April 08, 2022, 07:53:01 am »
It is likely to be the slider pins/bolts that are seized. Try to clean and lubricate the old ones, or buy new ones.
Not reccomending particular aftermarket parts but just for illustration:
https://www.ebay.co.uk/itm/261942591008
NorthWest
Just Arrived
-Given: 0
-Receive: 0
2007 GTI
Re: Brake issues
Reply #9 on:
April 08, 2022, 08:20:37 am »
They are brand new and greased mate . Came with the new caliper
Flyingscotsman
Always Involved
-Given: 26
-Receive: 23
Re: Brake issues
Reply #10 on:
April 08, 2022, 08:42:40 am »
OK that's something eliminated. Do they still bind with the old pads in?
Some of the VW pads come in different thickness (I think 12mm vs 15mm). I found this out as the bigger ones wouldn't fit, however possible that they 'just' fit but bind.
NorthWest
Just Arrived
-Given: 0
-Receive: 0
2007 GTI
Re: Brake issues
Reply #11 on:
April 16, 2022, 03:46:56 pm »
so new brake line and still no good still getting hot
drivers side disc heating up to 40 degrees plus
passenger side staying at 18/20 degrees...
no fault codes on scan... what to do next? local mechanic looked at it couldn't find anything wrong?
LC5F
Just look at my post count
-Given: 16
-Receive: 80
Re: Brake issues
Reply #12 on:
April 17, 2022, 12:50:03 am »
Did you properly wire brush and clean the hub face before putting the new disc in place?
Could be rust pushing the disc out of alignment.
All Things Mk5
Mk5 General Area
Brake issues
