Author Topic: Removing centre caps  (Read 2011 times)
Offline JoshB
« on: April 20, 2022, 10:34:10 pm »
Is there an easy way to remove the centre caps on my 17” Monza’s without having to take the wheels off? I’ve had a quick go with some plastic trim tools but they wouldn’t budge…
Getting too old for this...
Offline GreigC
Re: Removing centre caps
« Reply #1 on: April 20, 2022, 10:35:24 pm »
I believe you need to remove each alloy and pop them off from the inside.
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,131272.0.html
« Reply #2 on: April 20, 2022, 10:37:34 pm »
If you're not keeping them then drill or Stanley on them. I don't run any, they're a nuisance if you want access to axle bolts when they're on the ground.
If keeping I've seen some people put something super sticky on them and pull, like some gorilla tape.
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #3 on: April 21, 2022, 09:56:57 am »
stanly blade got mine out when i put new ones on, didnt have to take wheels off
Offline JoshB
« Reply #4 on: April 21, 2022, 07:15:14 pm »
Cheers.
Whilst I’m trying to keep my Golf “original”, 3 of the existing ones have basically completely whited over so I might drill a little hole in them.
I’ve bought VW ones to replace them, but Passat ones as I like the blue, but still an original VW part, so I guess it counts!
Also, if any mods are listening, the search function appears bust for me. But Google does find posts.
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #5 on: April 21, 2022, 08:17:27 pm »
i just bought a set off ebay for about £12.99  couldnt tell the difference,  really wasnt that hard to remove anything stiff that you can force down the side of it will pop it out, you could even superglue a piece of string on each one then pull them out
Offline LC5F
  • -Receive: 80
« Reply #6 on: April 21, 2022, 09:17:03 pm »
if binning - decent sized self tapper and vice grips
Offline Oldie05
« Reply #7 on: April 22, 2022, 11:45:31 am »
Bit surprised at the suggestions for removal. Surely they just "pop" out? Never experienced any issues with my 17 year old.
« Reply #8 on: April 22, 2022, 01:33:25 pm »
Yes they do just pop out if you remove the wheel, which is what the OP was trying to avoid.
