October 05, 2026, 04:52:00 pm
All Things Mk5
How to Guides / Troubleshooting
tfsi camshaft carrier girdle replacement
Topic: tfsi camshaft carrier girdle replacement (Read 2695 times)
Antreasv
Newbie
-Given: 0
-Receive: 0
May 06, 2022, 03:42:16 pm »
Hello guys.. Started my first project on a Tfsi engine!
Building a new engine with forged internals my cylinder head is a rebuild one and missing cams and carrier girdle caps.
My question is: Does it affect the engine if i will buy good cams and use from a different engine the carrier girdle caps?
LC5F
Just look at my post count
-Given: 16
-Receive: 80
Re: tfsi camshaft carrier girdle replacement
Reply #1 on:
May 06, 2022, 10:50:49 pm »
They should line up - but I would bolt it together without cams to check all the journals line up
breeze
Always Involved
-Given: 27
-Receive: 12
Reply #2 on:
May 07, 2022, 06:55:08 am »
Don’t forget that the fuel pump lobes on the intake cam wear. Check measurements before you install. Also make sure that you get a later intake cam because the design changed (it became two part) and the metal is harder.
pudding
Global Moderator
-Given: 2
-Receive: 692
Reply #3 on:
May 07, 2022, 12:37:24 pm »
Personally I would get hold of a complete head with cams. They are line bored at the factory to the cams as a complete unit. Not saying second hand cams wouldn't work, but to mitigate any risk of that......I'd get a complete head.
All Things Mk5
