Author Topic: Diverter Valve.  (Read 4274 times)
Offline imprezzaworks
Diverter Valve.
« on: May 19, 2022, 01:23:58 am »
Looking at doing a few jobs and thinking I may replace this too. Which one is the best or most reliable etc
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
Re: Diverter Valve.
« Reply #1 on: May 19, 2022, 09:06:04 am »
go for g,  £20 cheaper than d and works better, mine has lasted 2 years on stage 2 so far
Re: Diverter Valve.
« Reply #2 on: May 19, 2022, 09:07:50 am »
Just had a price off tps. £46+vat for the G.
I've owned the car for a while and I'm getting work done next week so will replace a few maintenance bits. Be handy if I decide to sell too.
Re: Diverter Valve.
« Reply #3 on: May 19, 2022, 09:27:58 am »
Ordered. Assume relatively straightforward to fit
Offline JoshB
Re: Diverter Valve.
« Reply #4 on: May 19, 2022, 10:31:02 am »
Yeah it’s a piece of cake. I had a rev G fitted by R-Tech in Nov last year. I feel like the cars lost a bit of power and I’m hearing whistling noises on acceleration so need to inspect mine…..
Getting too old for this...
  • -Receive: 692
Re: Diverter Valve.
« Reply #5 on: May 19, 2022, 11:59:26 am »
Also check the boost pipework for leaks as there are many causes of turbo whistle.  The worst one being the turbo itself, unfortunately.
Offline JoshB
Re: Diverter Valve.
« Reply #6 on: May 19, 2022, 12:58:56 pm »
Oh don’t…
I had some glitter in my oil filter…
  • -Receive: 692
Re: Diverter Valve.
« Reply #7 on: May 19, 2022, 02:56:34 pm »
I only said that because I've had to buy a new one myself for the same reasons.
My last 3 oil changes have had gold flecks in it, not loads, but enough to point the finger at turbo bearings.  Plus the whistling noise, reduced power/response, increased lag, reduced mpg.....
I'm glad the flecks weren't silver/copper coloured as that's far worse. New engine time.
Re: Diverter Valve.
« Reply #8 on: May 19, 2022, 03:11:08 pm »
Well all being well by next week
Wheel refurb.
Dv.
Oil change etc.
Maybe the steering rack. May go with the gen 3 off western power steering. I have someone who can code. Assume the gen 3 would be as straight forward to code as the 2?.
Then decide wether to sell and by a megane 250 or maybe we a newer golf.
  • -Receive: 692
Re: Diverter Valve.
« Reply #9 on: May 19, 2022, 03:18:34 pm »
I'm not sure you'd like the Megane for long once the novelty wears off.  They're a bit, erm, French  :grin:
I can recommend a MK6.  Really nicely made cars compared the MK5 and not too new, so that everything needs a laptop to fix like the MK7 & 8.
Gen 3 is easy to code, you just need to tell the ABS module to use the angle sensor in the rack, and not the column.  Then you just set the driver profile, I think I covered it all in the Gen 3 sticky thread.  No Gen 2 still uses the column clock spring like Gen 1.
Re: Diverter Valve.
« Reply #10 on: May 19, 2022, 04:29:09 pm »
Cheers. I've noticed lately I can hear like a clock spring noise lock to lock. Mine is lowered on h&r springs. Tbh it's probably always been like this, just noticed it due to the yellow steering light on.
I've had quite a few cliosports over the years. Fun cars.
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
Re: Diverter Valve.
« Reply #11 on: May 19, 2022, 10:17:28 pm »
my revision g from dealers was only £57 all in, and took 5 mins to swap once car was jacked up and supported with jack stands,  i take the wheel off slide my chest under the brake disc and use a 5inch t30 and and 10mm spanner,
Re: Diverter Valve.
« Reply #12 on: May 19, 2022, 10:19:15 pm »
Great stuff, sounds easy and have a ramp in work. Be interesting to see what the old one is like.
Offline mjmallia
  • -Receive: 60
Re: Diverter Valve.
« Reply #13 on: May 20, 2022, 08:19:17 am »
I relocated mine to the K04 position. A lot easier to check/change, but only did it as a project when I had boost issues a few years back......still a nice mod though  :grin:
Mike
South Coast
  • -Receive: 692
Re: Diverter Valve.
« Reply #14 on: May 20, 2022, 08:37:58 am »
Yeah I don't think I could be bothered with jacking the car up to check the DV, so good move relocating it to the front VW  :happy2:  Although VW were forced to do that as Borg Warner didn't put a DV port in the K04 turbo for some bizarre reason!
I think K03s eat DVs quicker than K04s due to the heat down there.
