Author Topic: Changing front seats  (Read 1734 times)
Offline Lewo
« on: June 18, 2022, 12:33:36 pm »
Just want to check before I knock my head off...
Disconnect battery and wait 30 mins.
Disconnect connection under seats.
Undo the 4 bolts. (what size are they and are they easy to undo or need a spray a while before?)
Cheers.
  • -Receive: 692
Re: Changing front seats
« Reply #1 on: June 18, 2022, 12:38:07 pm »
Sounds about right.  Do GTI seats have airbags? If so, those yellow connectors can be a bit finnicky, so don't be too shocked if you get an airbag warning light afterwards  :grin:  In my old MK4, I just sprayed a bit of contact cleaner on the plugs and reconnected to shift the fault.
Offline Lewo
« Reply #2 on: June 18, 2022, 02:01:34 pm »
Cheers pudding  :happy2:
Offline terrier
  • -Receive: 41
  • My Ride: GTI now gone
« Reply #3 on: June 18, 2022, 02:16:54 pm »
N90936901 M10 spline bolts  Just replaced mine £12 :happy2:
Offline Lewo
« Reply #4 on: June 18, 2022, 02:40:56 pm »
Hoping they come out ok and can reuse.... Maybe I'll spray them before tackling.
Offline terrier
  • -Receive: 41
« Reply #5 on: June 18, 2022, 09:10:43 pm »
Make sure the spline bit is seated correctly before attempting to remove the bolt Or else is vice grips :scared:
Offline ttelracs
« Reply #6 on: June 18, 2022, 10:01:40 pm »
I took mine out to clean last year July, just used the correct spline on a half inch ratchet and they all came out no problem.
I didn't disconnect the battery though and had no issues, in hindsight I should have and would do next time.
Offline JoshB
« Reply #7 on: June 19, 2022, 09:35:17 am »
Do mk6 seats bolt straight in?
Getting too old for this...
Offline Lewo
« Reply #8 on: June 19, 2022, 02:33:26 pm »
All done cheers.  :happy2:
