Author Topic: Carista Scan found a few fault codes.  (Read 1564 times)
Offline K03MK5
« on: February 08, 2023, 05:42:39 pm »
Any ideas on fixes for the fault codes below?
Steering wheel:
00576 - Terminal 15
00883 - Ignition starter switch (clamp S)
00884 - Ignition starter switch (clamp X)
01744 - Ignition/starter Switch (D) (Terminal P)
00885 - Ignition starter switch (clamp 50)
Radio:
00849 - S-contact at Ignition / Starter Switch (D)
00856 - Radio Antenna
00821 - Antenna 2 for Radio (R93)
Central electronics:
02390 - Control/regulation for ambience lighting (E400)
Thanks.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Carista Scan found a few fault codes.
« Reply #1 on: February 08, 2023, 05:50:17 pm »
First few are related to replacing the ignition switch.
tip - Google the numeric code and add ross tech wiki
I'm pretty sure the ambient lighting one is generated when you have a faulty door lock
« Last Edit: February 08, 2023, 07:59:32 pm by GVK »
Offline K03MK5
« Reply #2 on: February 08, 2023, 05:57:00 pm »
Yep guessed that.  Hoping I won’t need to replay the ignition switch.
Offline Jons1001
  • -Given: 22
« Reply #3 on: February 08, 2023, 06:06:47 pm »
I had the ignition switch codes about a year ago and decided to replace it before it went and i couldn't start the car. Replaced it and still have the first two codes in your post above...
