Author Topic: CANBUS Upgrade needed for simple single DIN stereo?  (Read 1631 times)
Offline OllieVRS
  • -Given: 17
« on: March 23, 2023, 12:42:07 pm »
Hi all,
Getting a bit sick of listening to CDs or shoddy quality music through a BT FM transmitter. Already tried installing just an aux with a standalone cable and CD emulator aux cable, both ended up having hissing or whining sounds, sounding worse than the transmitter.
Looking at getting a simple single DIN head unit, as I can use my phone for navigation etc. Something simple and cheap like a Sony DSX-A410BT, slightly higher RMS power than Skoda's OEM (25W vs 20W) so will sound even better. And I found a post on Briskoda saying the standard speakers can handle up to 30W.
It's one of those that you can remove the stereo face off of, do I still need to look at getting a CANBUS upgrade to prevent battery drain? No idea what version mine is, and my car has had a Parrot BT system installed (just for calls, not music), so there is one of those fuse box taps already installed I could reuse if absolutely necessary. It used to be plugged into the phone fuse before I unplugged it.
My Octy was registered May 2006 in case that makes a difference.
I know next to nothing about this topic, so any and all help is appreciated.
Cheers  :happy2:
« Last Edit: March 23, 2023, 01:42:54 pm by OllieVRS »
'06 Skoda Octavia vRS TFSI
Offline mjmallia
  • -Receive: 58
Re: CANBUS Upgrade needed for simple single DIN stereo?
« Reply #1 on: March 23, 2023, 02:01:24 pm »
You would need a quadlock to ISO adapter and then source a switched ignition from the fuse panel, as the car used CANBUS to turn the stereo on and off originally.
Mike
South Coast
Offline OllieVRS
  • -Given: 17
« Reply #2 on: March 23, 2023, 03:34:46 pm »
Thanks for the reply!
Does this look right? It includes a red cable to a pin that I assume is for connecting to the fuse box.
https://www.halfords.ie/technology/car-audio/stereo-fittings/volkswagen-audi%2Fseat%2Fskoda-iso-harness-adaptor---ct20vw02-581915.html
And my quadlock:
Getting a single din adapter and octavia fascia in Ireland is a bit of a nightmare though, so I may just be driving around for a while with a dodgy looking centre console  :grin:
« Last Edit: March 23, 2023, 03:37:02 pm by OllieVRS »
Offline mjmallia
  • -Receive: 58
« Reply #3 on: March 23, 2023, 03:53:36 pm »
Looks correct to me
Mike
South Coast
Offline OllieVRS
  • -Given: 17
« Reply #4 on: March 27, 2023, 12:30:09 am »
So... I know the forum may hate this install, but I've done an absolute fire-hazard of a DIY job to get it the new head unit installed  :grin: (I haven't managed to find a suitable single din fascia locally yet).
Unfortunately stays on with the ignition off, which was to be expected, as I'm too lazy to actually do the fuse box tap.
Although I did do a amp drain test with a multimeter, and removing the detachable front results in no extra drain. But if left connected, it turns itself back on after a while.
Offline OllieVRS
  • -Given: 17
« Reply #5 on: April 06, 2023, 03:02:30 pm »
Finally properly fitted, fire hazard averted  :smiley:
Bought the single din adapter off eBay for €36 with shipping to Ireland.
  • -Receive: 691
« Reply #6 on: April 06, 2023, 06:35:51 pm »
That looks fine  :happy2:
Interesting about the whine and hissing via an aux in cable.  What radio did you have in there originally?  I had a cheap old RCD 310 from ebay and that worked great with an aux in.  Obviously it's a faff hooking it up to a phone and having no control over the audio tracks but it sounded good at least.
On the harness of your new radio, it's normally a case of swapping the yellow and red wires over to stop it staying on with the ignition off.  Key out I assume?
