Author Topic: Pirelli Edition stage 2+ build - 09Pirelli  (Read 35966 times)
Offline 09Pirelli
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,133619.0.html
« on: May 31, 2023, 05:55:21 am »
Hi guys, this is the start of my build thread for my black 2009 Pirelli Edition , some info about the cars modification.
Follow my insta @ trgicpirelli
ENGINE:
BYD KO4
Miltek 3' catless downpipe
Miltek 3' cat back non res
Leyo intake
CTS R8 coil packs
Iridium spark plugs
VIS HPFP
VIS balance shaft delete
AKS runner flap delete
5mm banjo mod
140bar FRV
CTS turbo outlet pipe
CTS turbo muffler delete
Stage 2+ ECU tune by Lambda Performance
Stage 2 high torque TCU tune by Lambda Performance
HANDLING:
30mm H&R lowering springs
034 billet dogbone insert
CTS trans mounts
CTS engine mounts
Continental contact 6 tyres
COSMETIC:
Deep black pearl paint
Carbon fibre interior trim
R32 pedals
Apple car play headunit
LEYO aluminium Paddle shifter extenstions
Custom pirelli trim inserts for seat and console
Eye lids
Vented fog light covers
Sequential turn signals
Yellow fog lights
Black badges
Reverse camera from mk6
Black sun banner
Ingo noak diffuser
Kill all wipers delete
« Last Edit: December 20, 2023, 08:21:38 pm by 09Pirelli »
2009 Pirelli Edition Stage 2+
Offline 09Pirelli
Re: Pirelli Edition stage 2+ build - 09Pirelli
« Reply #1 on: May 31, 2023, 11:44:29 am »
this is what the car looked like when i got it, the pirelli wheels were in the boot with bald tyres so first thing to go was get tyres, the car also came with the miltek non res cat back exhaust so that saved me money plus i knew what downpipe i wanted to get then to make everything match, first mod i did was the yellow stipe on the grill to let everyone know it’s a pirelli edition
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
« Reply #2 on: May 31, 2023, 12:02:20 pm »
Hi there, have you got some pics of "custom pirelli trim inserts for seat and console"?
Offline 09Pirelli
« Reply #3 on: June 01, 2023, 07:16:02 am »
Now that the stipe is yellow and the Pirelli wheels are on I took her to her first car meet hosted by AKL hatchbacks
I was the only Pirelli edition there so I got tones of look’s because no one here knows these existed, it was completely stock at this point so the first thing to buy is an intake for all the nice noises
Offline 09Pirelli
« Reply #4 on: June 01, 2023, 07:19:13 am »
Intake has now been fitted along with some R8 coil packs (no photos sorry) , this was about all I did for the next couple of months it was just little cosmetic things, car had a service at this time so everything was running good and no problems at all.
Offline 09Pirelli
« Reply #5 on: June 01, 2023, 07:21:03 am »
My custom Pirelli insert were installed and made the interior really pop even tho there small they do make that much of a difference
Offline 09Pirelli
« Reply #6 on: June 01, 2023, 07:24:19 am »
My last bit of cosmetics for a while were installed, yellow fog lights with I wrapped myself with yellow vinyl off Ali express along with black eye lids to make the car more aggressive looking , I also added paddle shifter extensions, now it was time to actually put money into the performance side of things
Offline 09Pirelli
« Reply #7 on: June 01, 2023, 07:28:30 am »
First big mod was the 3’ catless down pipe from miltek I chose this because i already have a 3’ cat back on the car from the previous owner so it was an easy install and fit, car sounded so much better after and surprisingly with it being catless there was no drone at all, I went catless for performance reasons and here in NZ they don’t check for cats
Offline 09Pirelli
« Reply #8 on: June 01, 2023, 07:32:58 am »
I purchased some H&R 30mm lowing springs as these were recommended to me and local, car sits a bit lower but not stupidly low, so I liked that, after install the ride was a bit stiffer but not as stiff as I wanted it but that’s okay, if I was to do it again i would go for a stiffer spring and maybe a 45mm drop
Offline 09Pirelli
« Reply #9 on: June 01, 2023, 07:36:31 am »
Some parts have arrived, my VIS BSD, VIS HPFP, AKS runner flap delete and rs4 FRV had arrived along with a rev G diverter valve wich I already had on my car but oh well new stuff Is better than old.
Offline 09Pirelli
« Reply #10 on: June 01, 2023, 07:40:03 am »
I installed my VIS high pressure fuel pump and while the pump was off I did the 5mm banjo mod for more flow, this is a nice mod for anyone wanting to lower the duty cycle on there lpfp for for performance.
Offline 09Pirelli
« Reply #11 on: June 01, 2023, 07:43:32 am »
Next do do was the VIS balance shaft delete, fairly straightforward was a it of a pain to tighten everything up but otherwise only took a hole day 💀. I also did a fresh service as it was about time at this stage, after this install I did notice the rpm climb a bit quicker, and the car vibrated a little bit more but you can’t really tell once you get used to it.
Offline 09Pirelli
« Reply #12 on: June 01, 2023, 07:48:15 am »
A little break from performance side of things and I managed to get myself this super rare diffuser from ingo noak, took me a while to get this as I can’t read German and there side is in German they also don’t ship here so I had to get it form a Norwegian tuning company, car looks so sick with it and I also install a kill all I
Wiper kit for a sleek back look.
Offline 09Pirelli
« Reply #13 on: June 01, 2023, 11:28:31 am »
It was time for a carbon clean so I got all the new gaskets and brass brushes I needed and went to work, took about an hour and a half to take the manifold off, I fortunately did not have the dreaded Satan bolt so the intake was off in no time, I spent the rest of the day cleaning the valves. My valves weren’t to bad actually just a little build up in the middle but very easy to clean just time consuming.
Offline 09Pirelli
« Reply #14 on: June 01, 2023, 11:32:07 am »
While the manifold was off I installed my RS4 FRV and runner flap delete, these were straight forward installs, I fully removed the motor for the runner flaps to save weight. When the car was all back together I noticed a different induction noise and little burbles from the car. Start up’s weren’t bad it was on the colder side in the mornings I just let it settle for a bit longer but apart from that no major problems not even a fault code.
