August 19, 2026, 03:37:02 am
All Things Mk5
Mk5 General Area
Some Help Broke Down :(
Pages:
5
6
7
8
Topic: Some Help Broke Down :( (Read 26946 times)
dazza
Admin
Just look at my post count
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Re: Some Help Broke Down :(
Reply #75 on:
September 26, 2023, 09:37:05 am »
Got a price of
264.02
EUROS from the stealers
Head to block bolts 06D103385D 10
Adjuster Bolt 06D109281D 1
Head frame bolts N10554005 23
Crank pulley bolts N91143901 6
Timing belt N90945002 3
N90628303 2
N90597005 1
N91029602 1
N90596906 1
N10552402 2
oil pump bolts WHT000360A 1
N91149501 3 m7x58
WHT000006 4 m7x70
N10430502 1 m7x40
N91149601 1
05 | Tornado Red | DSG
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #76 on:
September 27, 2023, 06:59:57 pm »
Did a bit more scraping. Are these mating surfaces clean enough?
Did one pass with the honing tool. Hopefully this Is ok
LC5F
-Given: 16
-Receive: 80
Reply #77 on:
September 28, 2023, 03:13:39 am »
Just get a Victor Reinz head bolt kit & Head gasket set.
Timing belt, VW change supplier like shirts - get a kit from continental/gates/Dayco/INA all have been OEM suppliers, whatever kit comes cheapest with water pump
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #78 on:
September 30, 2023, 08:04:21 pm »
Had another go at the bores with a different honing tool.
Much happier now.
GVK
Won't Shut up.
-Given: 1
-Receive: 76
Reply #79 on:
September 30, 2023, 11:24:58 pm »
Looking good
Scirocco TDI GT
https://www.facebook.com/groups/gvkmotorsport
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #80 on:
October 05, 2023, 09:13:26 pm »
Started lapping the valves.
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #81 on:
October 22, 2023, 11:17:58 am »
Made a tool to remove the exhaust cam sprocket.
Hopefully next week all the parts will arrive
skkane
Always Involved
-Given: 0
-Receive: 5
Reply #82 on:
October 27, 2023, 08:41:35 am »
Set it like that myself. Hopefully timing will be correct when we start it up and check with vcds.
2007 ED30
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #83 on:
October 27, 2023, 11:05:52 am »
Something is wrong I cannot get the exhaust cam to tdc mark it will spring forward of back and not stay on it.
GVK
Won't Shut up.
-Given: 1
-Receive: 76
Reply #84 on:
October 27, 2023, 01:50:42 pm »
I have heard of that happening on the 2.0 TDI motors, but not the TFSI.
Scirocco TDI GT
RBS
Won't Shut up.
-Given: 0
-Receive: 49
Reply #85 on:
October 28, 2023, 12:42:40 am »
Just red the whole story…😱 but…
You’re on the right track
Now what I can See on your head…is your intake cam mounted correctly??
The cam locking tool must go in between the spares from the cams… I don’t see the openings in the intake cam?? Or am I wrong??
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #86 on:
October 28, 2023, 07:17:34 pm »
I marked the chain correctly but put it one the wrong way round.
I still can't get it to stay at tdc it spins forward or backwards?
Going to buy some new bolts on Monday.
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #87 on:
October 29, 2023, 07:36:22 pm »
My adjuster is sitting two teeth furter out. If i take off will it go back to normal?
from video i followed
Mine
Last Edit: October 30, 2023, 06:42:20 am by dazza
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #88 on:
October 31, 2023, 06:47:13 pm »
Mystery solved
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Reply #89 on:
November 01, 2023, 03:16:19 pm »
Pistons are in
Pages:
5
6
7
8
All Things Mk5
Mk5 General Area
