Author Topic: Front drivers window packed up  (Read 1981 times)
Offline Jons1001
« on: August 28, 2023, 09:49:42 am »
Morning all, my front drivers side window packed up yesterday. It makes quite a bit of noise when the switch is pressed but no movement whatsoever, just stuck.
Anyone advise what i should be looking for when i remove the door card? Is there a chance its just come off the rails? Cheers
Offline terrier
  • My Ride: GTI now gone
Re: Front drivers window packed up
« Reply #1 on: August 28, 2023, 02:13:58 pm »
Possible snapped cable  Door skin removal Take note of the skin screws as they are different,will need replacing exactly
Plenty of good guides "Y" shaped crash bar does NOT have to be removed Grease cable when fitted :happy2:
 Dont be tempted to buy cable only
Offline Jons1001
« Reply #2 on: August 28, 2023, 09:01:14 pm »
Hi thanks for the advice. Sorry to sound thick but when you say don't just buy the cable what else are you referring to?
Offline GVK
  • -Receive: 70
    • GVKmotorsport
« Reply #3 on: August 28, 2023, 09:52:29 pm »
i=oB08DxEU3b3ntmqG
Follow this guide then you can focus on the window regulator once the door skin is off.
You won't see anything taking the interior door card off other than a speaker :)
« Last Edit: August 28, 2023, 09:57:17 pm by GVK »
Offline gj124
« Reply #4 on: August 28, 2023, 11:14:08 pm »
I've done this job more than once on a few VW's and Audi's and I'd advise buying the entire regulator as an unit (already built up) they're cheap enough and it makes the job ten times easier than having to fiddle about with the cables and new clips etc.
Loads of youtube videos showing how to do the job. It's pretty straightforward. The regulator is bolted behind the inner door panel, you'll need to take the door card and the inner panel off to access it.
Offline Jons1001
« Reply #5 on: August 29, 2023, 08:16:02 am »
Thanks all, will give it a go next weekend when i have some spare time.
  • -Receive: 691
« Reply #8 on: September 01, 2023, 08:13:40 pm »
Yep get the entire regulator and for the love of god, don't cheap out on it otherwise you'll be back in there again 12 months later.  Get OEM, or Valeo or whoever makes it, from AutoDoc bare minimum.
Offline GVK
  • -Receive: 70
    • GVKmotorsport
« Reply #9 on: September 01, 2023, 09:34:39 pm »
My Scirocco one went last winter, It's not a like a mk5 where you take the door skin off, I faffed about with it in -2 degrees, decided F*** it and took it to the local main dealer.
£400 later it was fixed.  :scared: :jumping:
  • -Receive: 691
« Reply #10 on: September 01, 2023, 11:24:33 pm »
Yikes! Reminds me of the time I couldn't be bothered to change the rear calipers on my ED30 myself and dumped it off at the dealer.  £800  :grin:
Offline GVK
  • -Receive: 70
    • GVKmotorsport
« Reply #11 on: September 01, 2023, 11:31:19 pm »
They did at least wash and hoover it despite charging £98 + vat for 'diagnostics'
  • -Receive: 691
« Reply #12 on: September 02, 2023, 12:09:19 am »
£117 for a diagnostic scan  :surprised:
BMW only charge £26 for that  :grin: What's going on in the world where VWs cost more than Bimmers to maintain??!  :grin:
Offline terrier
« Reply #13 on: September 02, 2023, 07:53:03 pm »
In the good old days a scan was 2 beer tokens or was it 3
Offline GVK
  • -Receive: 70
    • GVKmotorsport
« Reply #14 on: September 02, 2023, 08:02:54 pm »
Not a scan no, more of a "yeah thats f*cked" as they looked inside the door (I'd already taken the door trim off)
