Author Topic: Attention ED30 and Pirelli edition DSG owners  (Read 6556 times)
Offline SpongeBob
« on: October 09, 2023, 09:28:17 am »
This issue applies to K04 engined DSG cars only, engine code BYD. Unfortunately it seems if you need to replace your flywheel you could be in trouble. The part is no longer available from VW and there doesn't seem to be any aftermarket options.
AKS tuning state: VW MK5 Golf GTI Editon 30 - BYD - 06F105266S (Part made obsolete In April 2023, obsolete without replacement)
Mine has developed a bit of a rattle and I'm guessing one of the damping springs have broken.
Does anyone know of a solution or does the Audi S3 flywheel fit?
Offline skkane
Re: Attention ED30 and Pirelli edition DSG owners
« Reply #1 on: October 09, 2023, 05:34:20 pm »
Plenty available over here.
LuK 415 0264 10
SACHS 2294 001 780
https://www.autopieseonline24.ro/oen/06f105266
2007 ED30
Offline SpongeBob
« Reply #2 on: October 09, 2023, 06:33:55 pm »
Those seem to be for manual.gearboxes. Can you confirm it will fit?
Offline GreigC
« Reply #3 on: October 09, 2023, 08:32:04 pm »
The GTI K03 cars share the same DSG gearbox flywheel as the K04 cars. Also they are available online from various companies.
Offline SpongeBob
« Reply #4 on: October 09, 2023, 09:23:05 pm »
I'm confused. AKS site say's they're different and the are no aftermarket flywheel options for K04 engined cars with DSG and genuine ones are no longer available.
Offline GreigC
Offline SpongeBob
Offline GreigC
« Reply #7 on: October 09, 2023, 09:54:30 pm »
The DSG gearbox is the same. The DSG flywheel is the same as GTI/ED30 & Pirelli. Only the diesel MK5 DSG is different due lower RPMS.
Over the years the DSG gearboxes were revised/improved hence different part numbers on the DSG blocks.
« Last Edit: October 09, 2023, 09:57:13 pm by GreigC »
Offline SpongeBob
« Reply #8 on: October 09, 2023, 10:09:38 pm »
Thanks for your help GreigC.  :happy2:
Offline rsbelly
« Reply #9 on: February 22, 2024, 03:03:22 pm »
Hi SpongeBob.
I’m having the same problem that you had. How did you resolve the issue, did you eventually find the correct flywheel or did you replace the flywheel with standard GTI or one from a different model? Any help would be greatly appreciated.
Offline SpongeBob
« Reply #10 on: February 24, 2024, 12:16:46 pm »
The standard mk5 GTi DSG flywheel fits. The only difference between the standard flywheel and the edition 30 / Pirelli edition flywheel is in weight. These cannot be got anywhere so the standard GTi dsg flywheel is the only option.
Offline rsbelly
« Reply #11 on: March 02, 2024, 08:54:46 am »
Just for further information we decided to use the flywheel from the Edition 35, just because it’s closer to the original power of the Edition 30/Pirelli.
VW part no 06F105266A (Edition 35)
