Author Topic: 000010 - Camshaft Positioner (Bank 1 Intake)  (Read 2379 times)
Offline swansem
« on: November 02, 2023, 06:37:19 pm »
Hey guys, I need some help, recently I did a full head rebuild on my car(valves, intake cam, guides, seals, etc) replaced timing belt, camshaft chain tensioner, and also swapped the turbo all at the same time. After I drove the car for a bit I got a CEL , these are the fault codes I got, any ideas what might be going on? The car starts and drives fine. I’ve replaced the camshaft sensors and checked the timing on the belt and it looks fine.
Offline swansem
Re: 000010 - Camshaft Positioner (Bank 1 Intake)
« Reply #1 on: November 02, 2023, 06:42:38 pm »
Wanted to add after I replaced both crankshaft  sensors the second fault code (the one that mentions engine speed sensor) went away, but the one that says camshaft positioner bank 1 is still present  :thinking:
Offline akbarirfan
  • -Given: 81
« Reply #2 on: November 03, 2023, 10:58:54 pm »
Potentially N205?
Offline swansem
« Reply #3 on: November 04, 2023, 01:19:45 am »
Potentially N205?
Definitely thinking at this point it will have to be either that valve or the cam timing itself is off…guess I’d start by the sensor since it’s cheaper/easier to do
Offline swansem
« Reply #4 on: November 04, 2023, 05:58:31 pm »
Found the culprit. If anyone gets this issue in the future. Make sure when you are replacing your camshaft chain tensioner, adjuster, etc. also get the 3 plastic O-ring seals for the camshaft adjuster. They get too brittle and tend to break when you install a new adjuster…this will save you from a big headache
  • -Receive: 691
« Reply #5 on: November 15, 2023, 11:48:03 am »
Yep, very common that /\.  New O rings will work fine providing the VVT adjuster hasn't got deep grooves gouged into it.
