Author Topic: Torque Specs – Front & Rear Discs/Pads – Mk5 GTI (BWA)  (Read 7073 times)
Offline Husy
« on: September 13, 2025, 06:22:11 pm »
Hey all, replacing front & rear discs/pads on my 2008 Mk5 GTI (BWA) with Delphi (GSF). Does anyone have all the torque settings to complete the job?
Offline ZoliWorks
Re: Torque Specs – Front & Rear Discs/Pads – Mk5 GTI (BWA)
« Reply #1 on: September 14, 2025, 12:17:16 pm »
The 2 guide pins the brake caliper sits on - 30nm
The 2 large bolts holding the brake carrier onto the wheel bearing housing - 190nm
Small screw holding the brake disk in place - 6nm
Brake bleeder bolt - 10nm
I recommend replacing the guide pins and the rubber housings they sit in. You can get parts from the QuickBrake brand which are cheap and decent. They are just some rubber sleeves, 2 pins with "locktite" applied onto them already and some vaseline.
If you are installing brand new pads and disks, you will need to undo the bolts for the brake carrier, otherwise the new disk does not fit. First install the disk, then the carrier, then the caliper with the pads in it already
The front brake pistons can be pushed back in place, the rear brakes require twisting and pushing at the same time so get one of those cheap brake piston toolkits.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline MKVASMR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,134365.msg1165175.html#msg1165175
« Reply #2 on: September 14, 2025, 12:45:19 pm »
Front:
Brake carrier to wheel hub 190Nm (clean if reusing)
Guide Pin to brake carrier 30Nm
Rear:
Brake carrier to wheel hub rear (renew) 90Nm + 90deg
Brake caliper to brake carrier bolts (renew) 35Nm
Front and rear disc retaining screw 4Nm
