Author Topic: Best oil for track  (Read 4106 times)
Offline fuscobal
Best oil for track
« on: April 15, 2010, 08:33:58 pm »
I don't know what to choose for track between 300V 5W30 and 5W40. Here's the specs :
300 V Power
5W-40
Oil for gasoline and Diesel 4 stroke engine
BIODEGRADABLE
100% Synthetic - Ester based
TYPEOFUSE
All types of gasoline and Diesel engines. Turbocharged or not.
All 4 stroke engines : turbocharged or not, multivalve, carburettor or injection system,
with or without catalytic converter.
Suitable for all types of fuel : leaded and unleaded gasoline, gasoil, LPG.
All types of use : racing, circuit, Road and off road rally, in town, road, motorway.
PERFORMANCES
Références SUBARU WRT
Exceeds standards : API SG / CD
CEC L-33-A-93 Biodegradability test.
Protects the environment. Contains biodegradable Esters from vegetable origin.
Very high lubricating power which decreases friction and wear.
Decreases fuel and oil consumption.
RECOMMENDATIONS
Oil change: according to manufacturers' requirements and according to your own use.
MOTUL 300V POWER can be mixed with synthetic or mineral lubricants.
PROPERTIES
Colour Visual Green
Viscosity grade SAE J 300 5W-40
Density at 15°C (59°F) ASTM D1298 0.893
Viscosity at100°C (212°F) ASTM D445 13.7 mm²/s
Viscosity at 40°C (104°F) ASTM D445 72.5 mm²/s
Viscosity Index ASTM D2270 196
Pour point ASTM D97 -36°C / -33°F
Flash point ASTM D92 222°C / 431°F
TBN ASTM D 2896 11.5 mg KOH/g
300 V Power Racing
5W-30
Oil for High Performance 4 stroke engine
Designed for professional of racing
TYPEOFUSE
Hill climbing, qualifying tests, monotype races, N group...
Engines causing a very low oil dilution by the fuel.
All circuit races, rallyes,...
Gasoline or Diesel conventional engines, Turbo or atmospheric, with or without catalytic converter,
using standard or unleaded fuel, gasoil, L.P.G..
PERFORMANCES
References HONDA MUGEN - OSELLA ALFA ROMEO ...
Exceeds standards API SH / CF
Ester synthetic bases and the specific anti-friction additivation allow to increase significantly the oil
resistance film, to reduce frictions in the engine, to maintain the oil pressure, and generally to decrease
working temperature.
Extreme resistance against coking at high temperature.
Provides a better oil circulation, easier revs-up, a very efficient cooling.
RECOMMENDATIONS
MOTUL 300V POWER RACING can be mixed with synthetic or mineral lubricants.
PROPERTIES
Colour Visual Orange
Viscosity grade SAE J 300 5W-30
Density at 15°C (59°F) ASTM D1298 0.871
Viscosity at 100°C (212°F) ASTM D445 12 mm²/s
Viscosity at 40°C (104°F) ASTM D445 71.1 mm²/s
Viscosity index ASTM D2270 166
Flash point ASTM D92 232°C / 450°F
TBN ASTM D 2896 9.4 mg KOH/g
Mk5 GTI 6MT - Revo stage 3
Re: Best oil for track
« Reply #1 on: April 16, 2010, 10:06:01 am »
5W-30 :happy2:
Offline fuscobal
« Reply #2 on: April 16, 2010, 10:39:16 pm »
Ok, thanks Hurdy. I've ordered that one !
Offline Bogdanbd
« Reply #3 on: April 16, 2010, 11:41:54 pm »
Hurdy why 5w-30?
The Revo guys here told me to use 5W-40 ( so I did).
4x4-O2 RS REVO stg 3 - 370HP-K04 turbo-Haldex controller-Autotech HPFP-S3 injectors-NGK sparks-RS4 FPR Valve-EVOMS CAI-S3 FMIC+Forge Twintercooler & Actuator-USP fluidampr-custom 3" Magnaflow exhaust-KW coilover kit V1-S3 brakes front/rear + TAROX F2000 discs-LOBA-Sachs stg 2-VF Mounts-BSH PCV revamp-Forge short shifter-W.A.L.K.-H&R AntiRollBar kit + BSH end links -Team Dynamics ProRace 1.21 8x8J Anthracite/White
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 96
« Reply #4 on: May 14, 2010, 04:49:55 pm »
5W-30 :happy2:
Why?
Agreed, 5w30 is the correct viscosity for normal roadcar useage.  But differing compromises may be needed for track useage.
