Author Topic: sat nav for standard stero  (Read 2086 times)
Offline oly2k2
  • Albion Till We Die!!
« on: April 20, 2010, 12:50:23 pm »
Hi All, Im thinking of changing my standard GTI Stereo, (i own a 2005 GTI) to one that has satnav built in, does anyone know if the satnav/stereo will plug straight in to my old din sockets or will i have to get a conversion kit of some sort. or maybe get a professional to fit it, it would be great if it were to just plug straight in but as for things being simple they usually arent...your comments are appreciated...thanks.
Offline 182_blue
  • -Receive: 54
Re: sat nav for standard stero
« Reply #1 on: April 20, 2010, 12:55:12 pm »
Are you wanting the VW satnav (i.e RNS510)
Offline oly2k2
« Reply #2 on: April 20, 2010, 03:43:40 pm »
yes blue... cheers
Offline Rhys
« Reply #3 on: April 20, 2010, 03:46:53 pm »
RNS510 is just plug and play.   In play 2007 car i just swaped over the head units.
Offline Neimad
« Reply #4 on: April 20, 2010, 04:10:27 pm »
It is plug and play though some VCDS magic may be required depending on where you source the RNS-510 from.
Also, since yours is an '05 you will either have to make sure your RNS-510 has a firmware of less than 1200 or you will need to replace and recode your CAN gateway otherwise your battery will be drained flat if you don't use your car for a day or two.
