Author Topic: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....  (Read 555502 times)
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
Re: NQS BBK A Not Quite So Big Brake Kit..With Install Pics
« Reply #390 on: October 05, 2011, 09:02:10 pm »
Well the calipers are ordered and should be here tomorrow, lets see how they cope with with a bit heavier front end?? Althought i have the S3 hubs and wishbones so lighter already?
Bring on the fitting kit, then maybe some track action baby see what this soot chucker can do.
Darren
Glad you told me you've got the S3 hubs....different bracket altogether!!!
Offline muckipup
  • -Receive: 25
« Reply #391 on: October 06, 2011, 12:16:32 pm »
Did you originally not bother with them?
Where did you source yours from? How much etc?
No, I skipped on them initially. I got them from Eurocarparts iirc. I think they were about 12 notes each.
I hear DaveB's point. However, I was running new discs and pads and still got a low speed squeel when braking. The antisqueel shims and a bit of Ceratec sorted everything out. Copper grease rots the heck out of Brembo seals as Dave has mentioned in the original NQS BBK thread.
« Reply #392 on: October 06, 2011, 12:55:34 pm »
I thought they were more like £50?
Also what is Ceratec?
Thanks for the heads up on copper slip, all the times I've read te NQS thread & I wouldn't have remembered.
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
"You get what you pay for."
« Reply #394 on: October 06, 2011, 01:29:01 pm »
http://www.amazon.de/Original-Pagid-CeraTec-metallfreier-Dauerschmierstoff/dp/B005J4CSD4
Oh is it the gel like equivalent of copper grease?
I have some by Ate in the cellar, thanks Bruce
**thanks given  :happy2:
« Last Edit: October 06, 2011, 02:04:21 pm by Tfsi_Mike »
Offline mortygttdi
  • -Receive: 146
« Reply #395 on: October 06, 2011, 02:26:53 pm »
Darren
Will that be a problem Dave or is it just a matter of fabing? hope Ive not caused any inconvenience?
Darren
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #396 on: October 06, 2011, 02:30:01 pm »
I think the adapter is made of a different material to avoid the steel fusing to the alloy S3 hubs or something along those lines so its same size and shape just a different material.
Offline muckipup
  • -Receive: 25
« Reply #397 on: October 06, 2011, 03:38:23 pm »
Yup but there are 4 needed for both calipers so 4 @ £12 and the £50 figure is pretty accurate.
« Reply #398 on: October 06, 2011, 03:48:17 pm »
Makes sense, it's been a long day lol.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #399 on: October 06, 2011, 03:55:59 pm »
The adapter for the S3 hub is different to the one for the GTI hub. The difference is 16mm, where the brakes are fitted.
« Last Edit: October 06, 2011, 05:40:45 pm by rex »
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #400 on: October 06, 2011, 04:20:56 pm »
Mike, this aluminium oxide based paste is even thicker than copper grease,
even more high temperature resistant and prevents electrolytic corrosion
of brake and suspension components.
VW recommends only to use this kind of grease (like VW's own 'Optimol').
Fwik Porsche was the first company that has given a similar recommendation.
And yes, the S3 alloy hubs are much 'bulkier' than the steel hubs. So longer
bolts and a different shaped mounting bracket are required.
Offline mortygttdi
  • -Receive: 146
« Reply #401 on: October 06, 2011, 05:25:18 pm »
Wow I didn't realise the difference was that big :surprised: the steel ones are massively heavier but so much smaller :scared:
Will wait for the brake god to sort them out then cheers for the input from every one, hopefully we'll see what the difference is cant wait :jumpmove:.
Darren
Offline mortygttdi
  • -Receive: 146
« Reply #402 on: October 08, 2011, 12:24:21 pm »
Hi guys just want to add that any body looking for calipers then check this company out its a high performance breakers yard Porsche, Ferrari, Lotus and TVR :happy2:
http://www.douglasvalley.co.uk/
On eBay they go by the name of SteveStrange007 £200 for Boxster calipers all day long and have a few sets in at the moment.
Darren
Offline mortygttdi
  • -Receive: 146
« Reply #403 on: October 13, 2011, 03:34:41 pm »
Right Dave asked me to put these pics up has he wanted to show how the bridge pipe was transfered across between calipers.
First one is of a nice caliper built up with a newly spliced brake warning loom notice the proper VW plug
This is a passenger side caliper with the bridge pipe at the bottom and the bleed nipples at the top and also the leading smaller piston, the bridge pipe WILL NOT just swap from top to bottom it needs to be swapped from the left caliper to the right caliper and top to bottom its the way the pipe bends.
I hope that helps any one fitting this excellent kit :happy2:
Dave I need a new small piston seal I managed to catch it while grinding the pegs down :confused:
Darren
Offline perky85
« Reply #404 on: November 12, 2011, 11:17:51 pm »
Are the Mk1 Leon Cupra R front calipers not the same as these porsche ones?
If not, what are the differences?
Obviously Leon calipers are still readily available, as are discs & pads at reasonable prices aswell
