August 31, 2026, 03:02:22 pm
All Things Mk5
Sat Nav and Car Audio
RCD300
Topic: RCD300 (Read 2773 times)
Chris
RCD300
April 25, 2010, 09:32:04 pm »
Im thinking of changing my RCD300 for something a bit better, my cars a 55 plate 06 model with an autochanger in the centre armrest.
What options have i got without spending a ruck of money
ollie288
Won't Shut up.
-Given: 21
-Receive: 13
Re: RCD300
Reply #1 on:
April 25, 2010, 09:33:13 pm »
RNS 510 if you want a nav. RCD 510 if you don't? Unless you want aftermarket?
Smudgster
Always Involved
-Given: 8
-Receive: 1
Re: RCD300
Reply #2 on:
April 25, 2010, 09:48:37 pm »
As per Ollie's comments
Chris
Re: RCD300
Reply #3 on:
April 25, 2010, 09:51:14 pm »
rns seems to be mighty expensive, the rcd will go straight in ?
Truckie
Always Involved
-Given: 14
-Receive: 18
Re: RCD300
Reply #4 on:
April 25, 2010, 09:53:35 pm »
Bit pricey and wish it was specced from new on mine, but its an awesome bit of kit. RNS should be the dearer of the two, just check your firmware as is discussed numerous times in various threads on here, re batry drain issues.
These are between £350-£600
Chris
Re: RCD300
Reply #5 on:
April 25, 2010, 09:55:13 pm »
im a bit stupid, whats firmware etc
Yellow
Taking part
-Given: 0
-Receive: 2
Re: RCD300
Reply #6 on:
April 26, 2010, 04:32:03 pm »
RCD510
Nice little upgrade, not as spec'd up as the RNS but can be had for a couple of hundred cheaper, however if you have a car that's earlier than a MY08 car you'll need the canbus gateway thingy updating with a new one that works with the 3rg generation stereos, the older gateways will drain your battery.
New gateway and fitting *could* set you back £150-200 so it sort of comes to the same price as an RNS.
If you pick up an older RNS you can fit this without the need for the gateway update.
RCD 510 comes with 6 CD MP3 changer built in, SD slot and a nice touchscreen
RNS 510 has a single DVD/CD slot, NAV, SD slot, higher res touchscreen, built in hard drive
http://www.my-gti.com/1101/upgrading-2nd-generation-radios-rcd-300-rcd-500-to-3rd-generation-rcd-210-rcd-310-rns-310-rcd-510-power-drain-issue
Chris
Re: RCD300
Reply #7 on:
April 26, 2010, 08:07:43 pm »
might save for an rns then
All Things Mk5
RCD300
