Author Topic: Recent Purchases Picture Thread!!  (Read 1600956 times)
Offline doylebros
  • -Receive: 310
« Reply #6390 on: December 16, 2015, 07:14:50 pm »
Just wasn't getting on with the Mercedes. Sold it this afternoon, lost more than i had hoped but thats the way it goes.
Needs:
VCDS lead (should never have sold mine)
Satnav retrofit
Evening Anthony - no hanging about there then Merc out MKVII in!
Looking forward to your build thread and pictures of the new motor - I was under the impression the MKVII's have a locked gateway so retro fitting the SatNav wasn't possible. I think they call "build protection security"?
It can be unlocked in a VW dealership, AFAIK. It needs to be connected to the VW system.
Wasn't that the idea of Odis2 - your built vehicle is cradle to grave so the cost of recycling is all what you predicted.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #6391 on: December 16, 2015, 07:16:57 pm »
I have no idea, now you've lost me with that. :laugh:
I have a friend who retrofitted xenons to his mk7 and he needed to go to a VW dealership to have the BCM "unlocked" to accept the coding bit that came with the retrofit kit.
Offline doylebros
  • -Receive: 310
« Reply #6392 on: December 16, 2015, 07:21:25 pm »
That's not how I understand this http://forums.ross-tech.com/showthread.php?2150-Component-protection-modules-2014
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #6393 on: December 16, 2015, 07:37:23 pm »
Hmm, I see what you mean.
I'll check with my friend who knows a lot about retrofits (and did most of my interior retrofits) to explain to me better how the new system works. He also retroffited the xenons to my other friend with the mk7 and told him he needed to go to a VW dealership to activate the xenons. The kit came with a bit that coded the BCM correctly with the xenons, but it only worked well after the car being connected to the VW system.
Offline doylebros
  • -Receive: 310
« Reply #6394 on: December 16, 2015, 08:03:14 pm »
j
This is worth a read http://forums.mwerks.com/showthread.php?7162969-Troubles-with-activating-Discover-Media-retrofit-at-VW-dealership&p=87629068
And wait with interest your friends answer as to how he got your equipment to work!
« Reply #6395 on: December 16, 2015, 08:17:03 pm »
Offline AJG09
  • -Receive: 21
  • My Ride: 2005 mk5 golf 1.6 FSI
« Reply #6396 on: December 16, 2015, 09:25:20 pm »
Nice where did you find that? Also will you be doing a guide for where the mounting bracket thingybobs go? Only reason I ask is I don't get where they are meant to go  :laugh:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6397 on: December 19, 2015, 10:01:55 pm »
Thought I'd pick up one of these for my tool box although never needed it may do some day  :rolleye:
For the less knowledgeable, it's a wiper arm puller for seized arms.
« Last Edit: December 19, 2015, 10:03:46 pm by r5gtt »
Offline doylebros
  • -Receive: 310
« Reply #6398 on: December 19, 2015, 10:04:09 pm »
http://i1374.photobucket.com/albums/ag433/Sandy1786/Mobile%20Uploads/Screenshot_2015-12-19-21-51-13.png
A very handy tool if your doing any gateway installs through the engine bay route.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6399 on: December 19, 2015, 10:12:27 pm »
I may start fitting in cruise control for the less fortunate but it's way too cold atm  :sad1:
Some of the lads on the tt forum are crying out for cc. and I need some pocket money.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #6400 on: December 19, 2015, 11:35:44 pm »
My friend who knows how to do retrofits installed xenon headlights in another friends Golf mk7. He told me that this generation needs to be connected to VW's database to receive the original factory definitions to make new modules installed work.
Not sure if this applies to radios...
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6401 on: December 20, 2015, 06:12:28 pm »
I'll ask a friend who works for vw ^^^  :happy2:
« Reply #6402 on: December 20, 2015, 06:19:40 pm »
Ill take a couple of pics when i fit it to show you where the mounts go :)
Offline AJG09
  • -Receive: 21
« Reply #6403 on: December 20, 2015, 07:10:53 pm »
Cheers that would be good  :happy2:
Offline Eccie
  • -Receive: 25
« Reply #6404 on: December 22, 2015, 02:09:14 pm »
At last BT have upgraded me to fibre, FTTP no less. I went for the 76mbps service, so after ditching the BT hub and going direct into my apple router's I thought I'd run a speed test over wifi on my mac sat at the kitchen table - I'm impressed
