Author Topic: Tyre Pressures (Again)  (Read 8566 times)
Offline nc35
  • -Given: 40
« on: May 19, 2010, 04:16:15 pm »
Still getting confused as to what is correct.  Just about to put some new Monza II and Sport Contacts on.   (18")
So want to get it right.
Sticker in the fuel flap says 2.4 bar (~36 psi).  Been reading you guys run anything from 30 to 40 psi.
Any advice please?
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Re: Tyre Pressures (Again)
« Reply #1 on: May 19, 2010, 04:32:11 pm »
your going to be met with a whole load of replies now.
best thing to do is play around and see what you prefer.
I personally found that anything over 34psi (on my 19s) is a bit harsh.
So i normally run about 32-33 all round.
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #2 on: May 19, 2010, 04:34:48 pm »
i set between the figures on the petrol cap, i've found you can really tell when you drive it if its on the low side as handling is  :surprised:
« Reply #3 on: May 19, 2010, 04:51:34 pm »
On the Ed30, 18" rims - it states 2.6 bar (37psi). But as above, these are recommended pressures. You can and should adjust as required. I'v found if I go too low, say 30psi, the handling is atrocious. Too high and the car is skittish.
Always remember to adjust the pressures when the tyres are stone cold. In fact, if you really wanted to, you could set them reasonably high and each morning, knock a few psi all round. Drive as normal during the day and see what feels comfortable.
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: May 19, 2010, 04:54:47 pm »
why does the GTI have such high pressures in comparison to the vRS??.
Mine states 2 bar front 2.1 bar rear  (30/31 psi) on 18" rims same width as your as well.
« Reply #5 on: May 19, 2010, 04:58:47 pm »
Probably because it's a performance car Sy.  :P  :laugh:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #6 on: May 19, 2010, 05:11:49 pm »
...........as above.  :grin:  :P
Offline Janner_Sy
  • -Receive: 113
« Reply #7 on: May 19, 2010, 05:31:57 pm »
lol, guess i walked into that one :grin:
any ideas though, id have thought it would have been the opposite with the vRS being the heavier car
« Reply #8 on: May 19, 2010, 08:03:59 pm »
Between 32psi and 40psi.....
The higher the psi, the better (generally) the MPG will be
The lower the psi, the better the linear traction will be in wet and dry. This is why you'll see some people lowering their tyre pressures before a trip down the 1/4 mile.
The higher the psi, the better the ride will be.
Lateral grip depends just as much on the construction of the sidewall as it will psi, I've found some tyres to perform better at lower psi and others at a higher psi, but I wouldn't go over 36psi for any 18" tyre (personal preference) :smiley:
Offline nc35
  • -Given: 40
« Reply #9 on: May 19, 2010, 10:08:22 pm »
Interesting to hear that higher psi will give a better ride.
At the mo I usually put 2.5 bar in. Compensation for the Tyres not being cold.
Also found higher pressures help keep the road noise down a little.
Wifes car runs at 32 psi on 17".  So surprised that the Golf is 36psi.
Is the sticker in the filler cap for 17" or 18"?  Is there any diff for the two?
Always been a bit anal about tyre pressure with previous cars. Checking every time I fill up.
No Golf anymore.
Thank You Everyone.
Offline gazbutS3
« Reply #10 on: May 19, 2010, 10:11:48 pm »
Sorry don't agree that the higher the pressure the better the ride John, the tyre is the first shock asorber, if the pressure is high the tyre won't give and the ride will be harsher IMO :smiley:
« Reply #11 on: May 19, 2010, 10:26:13 pm »
You should never use the garage pressure gauges they are wildly in accurate.  :smiley:
« Reply #12 on: May 19, 2010, 10:36:58 pm »
A lower air pressure for me gives worse bump and rebound, maybe down to the damper type. :smiley:
« Reply #13 on: May 19, 2010, 10:40:49 pm »
You need one of these. :happy2:
« Reply #14 on: May 19, 2010, 10:42:52 pm »
^^^I was expecting RR to post that!
