Author Topic: Free Golf Mk5 official workshop manuals  (Read 474460 times)
Offline SteveS
Re: Free Golf Mk5 official workshop manuals
« Reply #15 on: April 09, 2010, 01:19:43 pm »
links don't work now?
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline themonke
« Reply #16 on: April 09, 2010, 06:00:13 pm »
Fantastic. What an exelent find :drinking:
Next: Medium window tints & Lowering springs
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 96
« Reply #17 on: May 06, 2010, 07:12:19 pm »
Ho yus they doooo - - right click > save target/link . . .  :wink:
  • -Given: 88
  • -Receive: 96
« Reply #18 on: May 06, 2010, 07:14:17 pm »
Now added the full service manual for the DSG.  :star: :star: :star: :star:
Offline SteveS
« Reply #19 on: May 07, 2010, 11:40:13 am »
All i get is:
http://volkswagen.msk.ru/error.php
trying to see the engine docs.
SOLD!! :(
  • -Given: 88
  • -Receive: 96
« Reply #20 on: May 07, 2010, 11:57:57 am »
All i get is:
Right click > save target as (or save link as for Firefox).  They all defo work with IE6, IE7 & IE8.
Offline Janner_Sy
  • -Receive: 113
« Reply #21 on: June 20, 2010, 12:21:28 am »
MAINTENANCE PROCEDURES:
http://vwts.ru/service/g5_service_eng.pdf - Description of work
http://vwts.ru/service/j05_maintenance_01.pdf - Maintenance. Part 1 (for Jetta, but same as Golf V)
http://vwts.ru/service/j05_maintenance_02.pdf - Maintenance. Part 2 (for Jetta, but same as Golf V)
ENGINES - general:
http://vwts.ru/electro/g5/j05_27_el.pdf - Battery, Starter, Generator - 1.9L TDI-PD engine, 2.5L gasoline engine, 2.0L TFSI engine new
ENGINES - Volkswagen 2.0T FSI I4 engine BPY: (BPY is the North American variant [with different emissions gubbins] of the European AAX or BWA variants)
http://vwts.ru/engine/bpy/bpy_10-00.pdf - Technical data
http://vwts.ru/engine/bpy/bpy_10.pdf - Engine, removing and installing
http://vwts.ru/engine/bpy/bpy_13.pdf - Engine, disassembling and assembling
http://vwts.ru/engine/bpy/bpy_15-1.pdf - Cylinder head
http://vwts.ru/engine/bpy/bpy_15-2.pdf - Valve train
http://vwts.ru/engine/bpy/bpy_17.pdf - Lubrication system components
http://vwts.ru/engine/bpy/bpy_19.pdf - Cooling system components
http://vwts.ru/engine/bpy/bpy_19-01.pdf - Cooling system components
http://vwts.ru/engine/bpy/bpy_20.pdf - Fuel tank, Fuel supply system, EPC
http://vwts.ru/engine/bpy/bpy_21.pdf - Turbocharger, Charge air system
http://vwts.ru/engine/bpy/bpy_24.pdf - Fuel injection system Motronic MED 9.1
http://vwts.ru/engine/bpy/bpy_26.pdf - Exhaust system components, removing and installing
http://vwts.ru/engine/bpy/bpy_28.pdf - Ignition, servicing
ENGINES - Volkswagen 3.2 VR6 engine BJS - R32:
http://vwts.ru/electro/g5/g5_r32_bjs_wd.zip - Electrical Diagrams
TRANSMISSIONS:
http://vwts.ru/vw_doc2/trans/02e/at_02e_dsg_repair.pdf - 02E 6-speed Direct-Shift Gearbox (full service manual) new
SUSPENSION:
http://vwts.ru/suspension/g5/g5_40-2.pdf - Front suspension, servicing
http://vwts.ru/suspension/g5/g5_40-3.pdf - Front axle, tightening torques
http://vwts.ru/suspension/g5/g5_40-4.pdf - Subframe, stabilizer bar, control arms
http://vwts.ru/suspension/g5/g5_40-5.pdf - Wheel bearing, assembly overview
http://vwts.ru/suspension/g5/g5_40-6.pdf - Suspension, assembly overview
http://vwts.ru/suspension/g5/g5_40-7.pdf - Drive axle, servicing
http://vwts.ru/suspension/g5/g5_42-02.pdf - Rear suspension, servicing
http://vwts.ru/suspension/g5/g5_42-03.pdf - Rear axle, tightening torques
http://vwts.ru/suspension/g5/g5_42-04.pdf - Subframe, transverse link, tie rod, assembly overview
http://vwts.ru/suspension/g5/g5_42-05.pdf - Wheel bearing housing, trailing link
http://vwts.ru/suspension/g5/g5_42-06.pdf - Shock absorber, coil spring
http://vwts.ru/suspension/g5/g5_42-07.pdf - Stabilizer bar, assembly overview
BRAKES:
http://vwts.ru/brake/g5/g5_45.pdf - Electrical/electronic components and installation locations, Malfunction displayed by warning lamps for level control system, Hydraulic unit, brake booster/brake master cylinder, ABS system components on front and rear axles removing and installing, ESP system components removing and installing new
http://vwts.ru/brake/g5/g5_46-01.pdf - Front brakes, servicing
http://vwts.ru/brake/g5/g5_46-02.pdf - Rear wheel brakes, servicing
http://vwts.ru/brake/g5/g5_46-03.pdf - Parking brake lever
http://vwts.ru/brake/g5/g5_46-04.pdf - Brake pedal, assembly overview
STEERING:
http://vwts.ru/steering/g5/g5_48-02.pdf - General repair notes
http://vwts.ru/steering/g5/g5_48-03.pdf - Steering, torque specifications
http://vwts.ru/steering/g5/g5_48-04.pdf - Steering column, assembly overview
http://vwts.ru/steering/g5/g5_48-05.pdf - Electro-mechanical steering gear, assembly overview
http://vwts.ru/steering/g5/g5_48-06.pdf - Steering gear difference (Generation I and II)
http://vwts.ru/steering/g5/g5_48-07.pdf - Electromechanical steering gear, servicing (Generation I)
http://vwts.ru/steering/g5/g5_48-08.pdf - Electro-mechanical steering gear, servicing (Generation II)
BODY:
http://vwts.ru/body/g5/g5_50-01.pdf - Lock carrier (bonnet slam panel)
http://vwts.ru/body/g5/g5_50-02.pdf - Front wings
http://vwts.ru/body/g5/g5_50-03.pdf - Engine undertray
http://vwts.ru/body/g5/g5_50-04.pdf - Underbody trim
http://vwts.ru/body/g5/g5_50-05.pdf - Plenum chamber bulkhead
http://vwts.ru/body/g5/g5_55-01.pdf - Front hood (bonnet)
http://vwts.ru/body/g5/g5_55-02.pdf - Hatchback
http://vwts.ru/body/g5/g5_55-03.pdf - Fuel filler flap unit
http://vwts.ru/body/g5/g5_57-01.pdf - Front door
http://vwts.ru/body/g5/g5_57-02.pdf - Central locking system
http://vwts.ru/body/g5/g5_58-01.pdf - Rear door
http://vwts.ru/body/g5/g5_60-01.pdf - Sunroof with glass panel (Meritor)
http://vwts.ru/body/g5/g5_63-01.pdf - Front bumper
http://vwts.ru/body/g5/g5_63-02.pdf - Front bumper (GTI)
http://vwts.ru/body/g5/g5_63-03.pdf - Rear bumper
http://vwts.ru/body/g5/g5_64-01.pdf - Flush bonded windows
http://vwts.ru/body/g5/g5_64-02.pdf - Front door window
http://vwts.ru/body/g5/g5_64-03.pdf - Rear door window
http://vwts.ru/body/g5/g5_66-01.pdf - Wheel arch liners
http://vwts.ru/body/g5/g5_66-02.pdf - Exterior rear view mirror
http://vwts.ru/body/g5/g5_66-03.pdf - Radiator grille
http://vwts.ru/body/g5/g5_66-04.pdf - Strips and trim
http://vwts.ru/body/g5/g5_66-05.pdf - Rear roof edge spoiler (tailgate)
http://vwts.ru/electro/g5/g5_70.pdf - Instrument panel, Door trim, Pillar and side trim, Rear lid trim, Luggage compartment trim, Roof trim new
ELECTRICAL: -
http://vwts.ru/electro/g5/g5_gti_relay.zip - GTI Relay and fuse arrangements, from October 2005
http://vwts.ru/electro/g5/g5_gti_component.zip - GTI Component locations
http://vwts.ru/electro/g5/g5_gti_ground.zip - GTI Ground connection
http://vwts.ru/electro/g5/g5_90_eng.pdf - Instrument Cluster
http://vwts.ru/electro/g5/g5_91_eng.pdf - In Car Entertainment (Radios, Navigation system, Amplifier, CD Changer, iPod System, Speakers, Antennas, Multi-Function Steering Wheel, Mobile phone kit
http://vwts.ru/body/g5/g5_92_eng.pdf - Front and Rear Wipers
http://vwts.ru/electro/g5/g5_94_eng.pdf - Exterior Lighting systems (all components, including High Intensity Gas Discharge (HID) Lamps, High-Mount Brake Light, Steering Column Switches, Ignition/Starter Switch and Lock Cylinder)
http://vwts.ru/electro/g5/g5_96_eng.pdf - Interior Lighting systems (all components), Horns, Anti-Theft Immobilizer, Anti-theft Alarm System
http://vwts.ru/electro/g5/g5_97_eng.pdf - Fuse Panel, Relay Panels, Electronics Boxes (E-Boxes), Control Modules, Wiring Harness and Connectors, repairing
Rgds, and n-joy.  :happy2:
all those links are broken for me, anyone else having the same problem.  russian page appears which translates into an error message :happy2:
Offline Lean
  • DSG +..
« Reply #22 on: June 20, 2010, 05:26:05 pm »
I had the same problem a while ago but managed to navigate my way around - if you click the link below you select the areas from the page that loads  :happy2:
http://volkswagen.msk.ru/index.php?p=vw_golf5_1k
The one below lets you choose your vehicle  :smiley:
http://volkswagen.msk.ru/index.php?p=pl_a5
Offline Scotsman
  • -Given: 32
« Reply #23 on: June 20, 2010, 06:03:51 pm »
Didn't work for me at all with Firefox, but downloaded first time using IE8.
Offline Lean
  • DSG +..
« Reply #24 on: June 20, 2010, 11:22:28 pm »
I just tried with FF 3.6 downloads fine  :star:
Offline Janner_Sy
  • -Receive: 113
« Reply #25 on: June 20, 2010, 11:29:26 pm »
it opens fine for me now, automatically translatesthe first web page, but the 5mb PDFs are all in russian, are the english versions there as well?
  • -Given: 88
  • -Receive: 96
« Reply #26 on: August 30, 2010, 02:03:53 pm »
All the still definately work - in both Internet Explorer (6, 7 & 8) and Firefox (3.8).
You MUST >right click< the link, then >save target as< - and download individual documents to your own hard drive.
There are NO Russian language docs - if you are getting Rusky docs, you arn't following the very simple instructions at the top of the first post!
  • -Given: 88
  • -Receive: 96
« Reply #27 on: October 25, 2010, 06:43:44 pm »
More updates today, including some for the brakes. :happy2:
« Reply #28 on: February 08, 2011, 03:51:05 pm »
Brilliant.. thanks TT!
Offline mdslocombe
« Reply #29 on: August 11, 2011, 09:56:05 pm »
None of these work for me on newest version of firefox, I am right clicking and saving link as.. nothing but an error.
