Author Topic: DV  (Read 2453 times)
Offline johnboy07
DV
« on: September 26, 2010, 08:47:26 pm »
just new to this forum but not so new to golf gti's. did have a mk4 gti turbo and have just got hold of a mk5 gti. loving it and such an improvement on the mk4 which i loved.
Right on my mk4 i did sadly like the sound from the forge re circ i had fitted and wondered if it will sound the same on this. im booked in for stage one revo on saturday at 9.00am and cannot wait. Also have an ITG induction arriving this week and was also considering replacing the diverter valve with the D version from vw but want a bit of noise. does this have the same kind of noise or should i buy the forge and relocate it to the front.
thanks in advance and glad to be back.
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: DV
« Reply #1 on: September 27, 2010, 10:12:47 am »
The ITG will give a lot of noise so expect that will give you what your looking for.
Otherwise there is the option of the forge blow out valve but personally I think these aren't the best idea on a car with a system designed to recirc.
Offline AlanD
Re: DV
« Reply #2 on: September 27, 2010, 06:42:11 pm »
IMO your MUCH better off getting a proper valve that doesn't make a silly noise.
The latest revision VW one will do the job just fine. I've got a Forge (which also does the job alright) on mine but thats only because at the time when I got mine the VW ones weren't up to it.
Offline johnboy07
Re: DV
« Reply #3 on: September 27, 2010, 08:30:47 pm »
ok many thanks guys. just an update. ive installed the itg and your right. that now gives the same noise as my other golf. dont like it too loud just wanted a bit of noise. I do have a problem though. sometimes when i drive it it pulls ok and other times it hesitates and doesnt seem to sustain boost. then after fitting the itg i can hear what sound like an increased hiss as it reaches a higher pressure. sorry that doesnt make much sense but its as if with the higher pressure there is a leak. or cus this be the diverter valve failing, as its the older type. Have ordered the d type today from vw anyway.
thanks
Offline SteveS
Re: DV
« Reply #4 on: September 27, 2010, 09:44:18 pm »
doh, could have saved u some ££ but nm
good luck
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline johnboy07
Re: DV
« Reply #5 on: September 28, 2010, 07:34:20 am »
wish id read the message before buying but didnt see it until i got home. hope it sorts ma problem
