Author Topic: vRSAlex's Octavia vRS Estate - New Mods On  (Read 338854 times)
Offline rs_t
Re: BDMAlex's Octavia vRS Estate
« Reply #165 on: November 14, 2011, 12:27:05 pm »
Great project. What size and ET are the BBS CK's? What tires are you running?
Offline vRSAlex
  • -Receive: 253
« Reply #166 on: November 14, 2011, 09:44:57 pm »
They are 8x18, et44 with 225/40/18's  :happy2:
Follow AKS tuning on Facebook
Offline vRSAlex
  • -Receive: 253
« Reply #167 on: November 15, 2011, 08:13:38 am »
New valve.  The Forge Supersize.  Fitted these in the past and they have worked very well and respond even faster than the D valve.  Even holding boost better.
Got it fitted last night and a massive improvement noticed straight away.
« Reply #168 on: November 15, 2011, 11:23:29 am »
How much would this be and how easy to fit to Leon Cupra that curently has forge valve?
Offline vRSAlex
  • -Receive: 253
« Reply #169 on: November 15, 2011, 12:15:01 pm »
All you need is the valve, a 38-25mm reducer hose, a 25mm hose joiner, 45mm hose clip and a 25mm hose clip.  The reducer hose needs cutting down.
Then needs a vac line from the inlet which you already have for the other forge valve.  The N75 valve still needs to be plugged in electronically, but no hoses.  This stops any error codes.
I will pop to the car and get some pics of it fitted.
Offline damoegan
« Reply #170 on: November 15, 2011, 12:30:12 pm »
Interesting  :popcornsoda:
« Reply #171 on: November 15, 2011, 12:32:34 pm »
Didn't answer the important question :p  :evilgrin:
Offline damoegan
Offline vRSAlex
  • -Receive: 253
« Reply #173 on: November 15, 2011, 12:38:12 pm »
Ok Ok.  I found it very easy to fit!
£106.51 for the valve
£6.60 for the hose joiner
£10.20 for the silicon hose
Few quid for the hose clips
You have the other parts, but most people would also need the N75 and the boost tap.
h4rdy
« Reply #174 on: November 15, 2011, 12:38:50 pm »
When Alex doesn't answer that question it means a lot!
h4rdy
« Reply #175 on: November 15, 2011, 12:40:01 pm »
It was a joke btw.
Alex you have mail about next Wednesday.
« Reply #176 on: November 15, 2011, 12:40:47 pm »
Thank you! :D
Offline vRSAlex
  • -Receive: 253
« Reply #177 on: November 15, 2011, 02:04:22 pm »
Some pics of the valve all fitted
The vRS doesnt have the 'OFF' or 'DUAL' buttons on the climate control so I grabbed a Golf unit and swapped the buttons over
Before:
After:
Also picked up some black caps from Sixonetwo to cover up the rusty BBS bolts
« Reply #178 on: November 15, 2011, 03:16:43 pm »
Worth trying over the normal forge valve?
Would rather order from you than Forge due to all the advice you've provided me with on here.
Would it be worth you selling me the bits at that price or should I go to Forge site with SCN 10% code?
Offline Gti_Mad
« Reply #179 on: November 15, 2011, 08:27:40 pm »
i would be up for this also
groupbuy of kits mike ???  :signLOL:
