Author Topic: LED number plate lights  (Read 23299 times)
Offline S800BRN
  • -Receive: 27
Re: LED number plate lights
« Reply #30 on: November 11, 2010, 12:34:48 am »
Fitted the plate LEDs. Also ordered a set of m-tecs for the puddle lights to match my sidelights.
Offline GeeTeeI
« Reply #31 on: November 11, 2010, 05:20:03 pm »
looks great and now alls you guys need to do is your interior bulbs  :P  :signLOL:
How do you get the interior bulbs out?
I want this look in my car!
Did the sidelights today - took about 5 mins and looks absolutely brilliant - though haven't worked out how to post yet! plus my car is filthy...
Anyway, now I want to do the interior lights - but I have a query with regards to the fade out feature - does fitting LEDS romove this - I assume it does as they will switch off once there is a slight voltage drop.
Also: what is the shopping list for the interior bulbs - how many and what types?
Thank you
Mark
Offline v2brett
« Reply #32 on: November 11, 2010, 06:11:07 pm »
they do still fade, but im not sure how much compared to the standard bulbs.
bulbs for interior are;
2x error free canbus 501 led bulbs
5x normal 501 led bulbs
1x  36mm festoon bulb
plus the 2 vanity mirror bulbs, but im not sure on type as i havent done mine
Still Here!
Offline Gti_Mad
« Reply #33 on: November 12, 2010, 12:06:04 pm »
the 2vanity mirror 1's are normal festoon bulbs
anyone done the glovebox bulb  :signLOL:
Offline roamer1711
« Reply #34 on: November 12, 2010, 06:28:27 pm »
oops I have ordered all no error 501 leds :stupid: presume they will still fit. are the festoon bulbs defo 36mm as I seem only to find 38mm ?
Went in for a Landy came out with a GTI, mid life crysis? me :-)
« Reply #35 on: November 12, 2010, 06:35:08 pm »
Okay guys, don't get me wrong - I love LED's, but why on a number plate?
The only reason I can think of is to highlight a private plate, but why light up a gobblygook plate?  :confused:
Offline Weston
« Reply #36 on: November 12, 2010, 06:35:57 pm »
Yep, and the boot  :happy2:
GTI going...
Offline Weston
« Reply #37 on: November 12, 2010, 06:39:32 pm »
I used these and they fit at 39mm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180488092757&ssPageName=ADME:B:EOIBSA:GB:1123#ht_3813wt_922
Have a look on here
http://www.golfgtiforum.co.uk/index.php?topic=156137.0
GTI going...
Offline GeeTeeI
« Reply #38 on: November 12, 2010, 06:40:28 pm »
Are the boot and the glovebox both normal festoon ones?
OI assume the only ones that are canbus in the interior are the footwell ones in the front?
Offline v2brett
« Reply #39 on: November 12, 2010, 06:40:54 pm »
I think it makes the car look that little bit more modern.  im sure all new bmw's come with them standard now.
Still Here!
« Reply #40 on: November 12, 2010, 06:44:38 pm »
....Oh dear! I think you're right. Which means I should seriously consider them  :grin:
I need help!!:
Offline v2brett
« Reply #41 on: November 12, 2010, 06:46:27 pm »
 :signLOL: you didnt nearly fall off the slippery slope did you Robin
Still Here!
Offline Weston
« Reply #42 on: November 12, 2010, 06:53:25 pm »
Here's what they all are:
501's for sidelights (2), footwells (2), ceiling (5), glovebox (1)
Festoons for ceiling (1), vanity mirrors (2), boot (1) and number plate (2)
With the boot the bulb isn't long enough but a folded up piece of foil works  :smiley:
GTI going...
Offline alastairc
« Reply #43 on: November 15, 2010, 08:30:14 pm »
I fitted puddles no problem, but trying to do foot wells seems a nightmare!
They didn't pop out with screwdriver so I removed the trim to get at them from above but found what seems like a sealed plastic lens and pressed metal unit?
Its an 06 plate so cannot be different to what you guys have already done - am I missing something?
Any ideas welcomed,,,
Mk5 GTI DSG, Stage 2 Bluefin, Revo DSG Remap, Miltek Stainless Turbo back with Race cat, Forge Twintercooler, Carbonio Intake, Upgraded Disks and Green Stuff Pads, Konzept Open Fogs, Upgraded OEM Divertor, Leather, SatNav.
Offline Weston
« Reply #44 on: November 15, 2010, 09:49:38 pm »
You'll see some metal tabs holding the plastic in place. You have to carefully prise the open then wiggle the lens free. It's fairly simple, just don't rush as you need to put it back together and bend the tabs back. From memory there's just 2 at each end  :happy2:
GTI going...
