Author Topic: Hot Climate Radiator Part No?  (Read 1662 times)
h4rdy
« on: October 15, 2010, 05:38:58 am »
Anybody got the part no?
A Link or even the Radiator?
J
Offline bacillus
  • -Receive: 453
Re: Hot Climate Radiator Part No?
« Reply #1 on: October 15, 2010, 09:41:34 am »
Hmm, why, do you want one?
Offline fuscobal
« Reply #2 on: February 06, 2013, 07:55:58 pm »
Ok chaps, back with some real info. Just got the latest ETKA so I pulled out some codes following the VIN of my car and a friend's mk6 R20 wich has the additional radiator installed. Here we go :
1) 5 > 1k0 121 156 BA or BJ > there are 2 codes here, both for hot climate, both under my VIN and I've attached a pic with the explanations below each of them, maybe someone could tell the difference
My mk5 GTI AXX  > doesn't have it at all of course
Friend's R20 > 1k0 121 156 BJ
2) 7 > 1k0 121 156 BC
Friend's R20  > 1k0 121 156 BC
3) 10 > 1k0 121 087 J > I believe this is the quad connector Daigo was talking about
My mk5 GTI AXX  > N 906 929 01
Friend's R20 > N 906 929 01 > as you can see the R20 has the same code as me here wich means mine should be ok but I'll order the other code just to be sure since this one is not expensive
4) 15 > 1k0 965 561 D
My mk5 GTI AXX > 1k0 965 561 G
Friend's R20 > 1k0 965 561 G > again same code as me so mine should work also. This time I'll keep my pump since it's about 150Euro
5) 34 > 1k0 121 064 A
Friend's R20 > 1k0 121 064 A
6) 37 > 1k0 122 051 BC
Friend's R20 > 1k0 122 051 GP > different code, I'll stick with the one with BC as this one might be vehicle specific (GP doesn't show under my VIN either)
7) 40 > 1k0 121 212 C
Friend's R20 > 1k0 121 212 C
8 ) 41 > 1k0 121 333 A
Friend's R20 > 1k0 121 333 > different code, doesn't show under my VIn so I'll go with the one ending in ''A''
9) 43 > 1k0 122 291 M
My mk5 GTI AXX > 7m3 122 291
Friend's R20 > 1k0 122 291 M
10) 47 > 1k0 121 101 CB or CC > CC is the one that shows under my VIN as optional part for hot climate
 Friend's R20 > 1k0 121 101 CC > he has CC either and I should be going with CC either since it's the one under my VIN
11) 46 > 1k0 122 101 DK > this is the code I now have on my car and there's no refference in the list posted by daigo about this one but under my VIN there are several options for hot climate (see pic below). Optional codes for this one are > 1k0 121 101 CA, 1k0 122 101 EA and 1k0 121 101 CC > really confused here as I don't know if I need this one and why so many codes ! The R20 has 1k0 122 101 JT wich is neither of the above 4 so it doesn't help at all !
12) 35 and 36 > N 015 082 13 and N 909 083 01 > some nuts (screw) that have the hot climate mention and I don't have on my car now. They can be seen in one of the attached pics and may come with the radiator !? I will oreder them just to be sure since they cannot be too expensive ! The R20 has N 015 082 13 (1pcs) and N907 611 02 (1pcs). Last one is different as you can see !
Uploaded with ImageShack.us
« Last Edit: February 06, 2013, 08:05:45 pm by fuscobal »
Mk5 GTI 6MT - Revo stage 3
