Author Topic: Launch control  (Read 5447 times)
Offline S800BRN
  • -Receive: 27
Launch control
« on: October 30, 2010, 12:23:47 am »
Hi all
Just a quick one - was launch control only introduced on newer DSG GTIs? Mine's an '05 plate and doesn't seem to have it.
You reckon it could be 'flashed' to the DSG ecu?
Cheers in adavnce
Re: Launch control
« Reply #1 on: October 30, 2010, 12:43:58 am »
I'm not sure buddy.... but did you turn the traction off first?  :happy2:
Offline S800BRN
  • -Receive: 27
Re: Launch control
« Reply #2 on: October 30, 2010, 07:36:39 am »
Yeah, Monte ESP was indeed off. Was just trying it like I'd seen in YouTube tutorial vids.
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: Launch control
« Reply #3 on: October 30, 2010, 08:37:56 am »
Tried the launch control on my car several times...you're not missing much!
Offline mb
  • -Receive: 29
Re: Launch control
« Reply #4 on: October 30, 2010, 10:19:29 am »
Was the engine up to temp as it wont work otherwise.
Re: Launch control
« Reply #5 on: October 30, 2010, 10:25:56 am »
I shouldnt worry if you havnt got it... Its one of those things you do once to see if it works, then never use again!
Offline swf7y
Re: Launch control
« Reply #6 on: October 30, 2010, 10:32:39 am »
I don't use it much but I think it's great  :laugh: :jumping:
Offline Weston
Re: Launch control
« Reply #7 on: October 30, 2010, 10:44:45 am »
Mines an 05 and has it, not that it gets used often though but it's good  :grin:
GTI going...
Offline GTIjames
Re: Launch control
« Reply #8 on: October 30, 2010, 10:51:48 am »
Revo dsg map will activate it for you if you havent got it  :happy2:
Also increases the launch rev limiter to c4k revs which allows you to really light up the tyres if you so wish  :driver
Offline chrishalfpenny
Re: Launch control
« Reply #9 on: October 30, 2010, 02:58:14 pm »
I thin k you can take your car to vw and they will activate launch control for you
Offline edd666999
  • -Receive: 89
Re: Launch control
« Reply #10 on: October 30, 2010, 03:04:54 pm »
Like previous posts u use it once and then don't bother. It doesn't really control any launch, you might as we'll just turn ur esp off and put ur foot down, u use just as much rubber.
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: Launch control
« Reply #11 on: October 30, 2010, 06:24:27 pm »
its definitely on the 05 DSG's it is just part of the software that gear box manufacturer designed for it.  And it really isnt worth paying to activate if you dont have it ive used it once and putting it in sport will actually get you off the line quicker than launch control as there is just no traction!
Re: Launch control
« Reply #12 on: October 30, 2010, 06:39:58 pm »
If you have the REVO DSG remap then the launch control comes into it's own. As long as you are in manual or sport modes, and the traction control is off, the LC is permanently active. So, you can launch easily without going through the rigmarole of faffing with the brake then swapping modes then brakes then traction off etc etc. It makes the LC user friendly. :happy2:
Nasir
Re: Launch control
« Reply #13 on: October 30, 2010, 06:56:56 pm »
There's no traction because you're launching at too many revs. It's upto 3000 RPM, depending on your tyres and the road condition you should find which is best for you.
Offline simey
    • Sismotorsport
Re: Launch control
« Reply #14 on: October 31, 2010, 03:53:32 pm »
Which way is quicker, using the manual mode or the launch control?
