Author Topic: Ed30 owners - what were the optimum settings for your car on Revo Stg 1?  (Read 6171 times)
Offline berg
  • -Given: 49
  • -Receive: 38
As am getting Revo on Fri just wanted an idea which were the best settings for you? I have a manual box and i know that no tweo cars ae the same so what suited your car may not suit mine.
I have read that F should prob be 9 as will only have a stock fuel pump but waht about B & T?
Cheers in advance
Offline NB07
Re: Ed30 owners - what were the optimum settings for your car on Revo Stg 1?
« Reply #1 on: December 08, 2010, 09:31:27 am »
the dealer will set it up for you but it will more than likely be T5 or 4 and F9 boost can be any where, mine was initially 7 then i upped it to 9 for a kick but was advised not to keep it on 9 as it could stress the turbo. mines on 666 now but i have a few more mods :smiley:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: December 08, 2010, 11:14:39 am »
cheers, so if i dont want to stress the turbo/clutch maybe a B6 and T5? will be running it on tesco momentum as no shell by me and the bp ultimate stuff is more expensive but not as good as "every little helps"  :grin:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: December 08, 2010, 01:05:20 pm »
B7 T4 F9
definitely F9 for std pump cars
T could go up , but you need to be running 98+RON fuel otherwise youll get timing pullback.
needs to be logged on safe settings then dialled up with more logging for optimal  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #4 on: December 08, 2010, 03:02:02 pm »
B7 T4 F9
thanks john, i saw the other thread after i had posted this. So if running momentum or v power do you think timing could go to 5 or better to play safe on 4 and see how it performs?
Offline PDT
  • -Receive: 142
« Reply #5 on: December 09, 2010, 08:38:43 pm »
You are paying for REVO so they will go out in the car and datalog it, then set it up accordingly. If they have one, then they may set it up on the dyno.
« Reply #6 on: December 09, 2010, 08:47:07 pm »
I have two settings:
B7 T5 F9 - more power
B6 T6 F9 - smoother
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #7 on: December 10, 2010, 04:44:56 pm »
B7 T4 F9
got mine done today but left it with 6/5/5 till i get used to it then planned to up the boost to 7 and f too but pipewerx said it did not need to be F9 and F5 would do the job? seems to run ok so far...
Offline robern2
« Reply #8 on: December 11, 2010, 08:47:02 am »
fuel 5 is extremely rich. Not heard of anyone else needing such a setting with stage 1  alone.
« Reply #9 on: December 11, 2010, 09:08:10 am »
Also not much real benefit without an upgraded hpfp.  :confused:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #10 on: December 11, 2010, 02:36:30 pm »
pipewerx said that these were the default settings from revo? Excuse my ignorance but a rich fuel mixture will mean what exactly? worse mpg? not enough fuel getting through pump into chamber to make good power?
« Reply #11 on: December 11, 2010, 04:34:42 pm »
Maybe for a 1.8T but not for a TFSI  :stupid:
On a bog standard car something in the region of B6-T4-F9 maybe but as people say Revo is entirely adjustable so you go with what the experts recommend.
« Last Edit: December 11, 2010, 04:36:26 pm by Hedge »
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #12 on: December 11, 2010, 05:18:48 pm »
just looked on the sps switch pdf doc and the default settings appear to be 6/5(for 98+RON) and 9 unless you "understand AFR" will see how it runs but i need to take it into awesome anyway for a run on the dyno so see if they recommend changing F setting
Offline PDT
  • -Receive: 142
« Reply #13 on: December 11, 2010, 06:43:01 pm »
Its very odd for a car to be datalogged and left on F5 unless you need such a rich mixture. Without an uprated HPFP then F9 is far more likely to be correct.
Did they give you any copies of the datalogs?
« Reply #14 on: December 11, 2010, 09:26:48 pm »
Are you sure they said five and not nine? Could be easily misheard/misinterpreted.
