September 02, 2026, 03:51:49 pm
All Things Mk5
How to Guides / Troubleshooting
EVAP EMISSION CONTROL SYSTEM FAULT
Topic: EVAP EMISSION CONTROL SYSTEM FAULT (Read 3090 times)
jimmy-s3
Won't Shut up.
-Given: 1
-Receive: 7
January 22, 2011, 11:38:03 am »
Ive already found one slight leak on the evap system(charcoal canister return pipe) but its now showing another fault. Is there anywhere else on the evap system prone to fault?
vRS Carl
Just look at my post count
-Given: 282
-Receive: 241
I'm the F.A.G (Forum Apple Guru)
Re: EVAP EMISSION CONTROL SYSTEM FAULT
Reply #1 on:
January 22, 2011, 12:01:49 pm »
You may need a new canister. I replaced the breather pipe on mine and it's been ok since touch wood
jimmy-s3
Won't Shut up.
-Given: 1
-Receive: 7
Reply #2 on:
January 22, 2011, 12:36:54 pm »
which breather pipe carl?
I resealed the pipe which is on the top of the canister as it seemed loose( it seemed to push in place then twist in or something, but it seemed as if the rubber seal was worn).
This worked last time when the fault appeared!
vRS Carl
-Given: 282
-Receive: 241
Reply #3 on:
January 22, 2011, 12:44:51 pm »
Thats the pipe You need to order an O-ring to go with it.
Part no.s
Breather Pipe - 1K0 201 160 BG.
O-Ring - N 028 223 1
£13.50 for the lot inc VAT
jimmy-s3
Won't Shut up.
-Given: 1
-Receive: 7
Reply #4 on:
January 22, 2011, 12:54:25 pm »
yeah but that pipe seems fine?
Plus, ive just connected the battery back up after changing the cam follower and now ive got 3 warning lights up, steereing, asc and tyre pressure? Why will that be?
vRS Carl
-Given: 282
-Receive: 241
Reply #5 on:
January 22, 2011, 01:55:26 pm »
That's just because the battery has been off.
Drive about 50m and they will go off
jimmy-s3
Won't Shut up.
-Given: 1
-Receive: 7
Reply #6 on:
January 22, 2011, 03:57:36 pm »
As Carl said...
They have gone off!
Cheers carl
All Things Mk5
