Author Topic: DSG Kickdown  (Read 3437 times)
Offline rsreid2000
DSG Kickdown
« on: January 25, 2011, 07:06:50 pm »
When driving in D and I floor it to activate the 'kickdown' sometimes it is scary fast and other times it seems flat.
I've watched and it always drops 2 gears.
I'm I doing something wrong.
Is there a certain way to use the 'kickdown' feature.
Offline edd666999
  • -Receive: 89
Re: DSG Kickdown
« Reply #1 on: January 25, 2011, 07:09:40 pm »
mines the same, i just use 'M'
Re: DSG Kickdown
« Reply #2 on: January 25, 2011, 07:11:26 pm »
It all depends how hard you press, its a 2 stage kickdown
With your car turned off... press the accelerator to the floor, you should feel a switch clicking at the very bottom.
When you press it fully down till the switch clicks then it will drop to the lowest gear possible, if you only press it so the switch doesnt click... is will change down maybe 1/2 gears depending and it will do it less aggressively.
Offline rsreid2000
Re: DSG Kickdown
« Reply #3 on: January 25, 2011, 07:19:25 pm »
Thanks richwig83.
I will try that tomorrow.
I try to be aware that I I'm pressing all the way down.
Re: DSG Kickdown
« Reply #4 on: January 25, 2011, 08:18:11 pm »
Also that kickdown past the switch point works in Manuel unless you have a DSG map.
Offline rsreid2000
Re: DSG Kickdown
« Reply #5 on: January 26, 2011, 08:08:11 am »
I don't seem to hear a click when I press fully down!
h4rdy
Re: DSG Kickdown
« Reply #6 on: January 26, 2011, 09:03:57 am »
It will just feel like a switch at the bottom.
Maybe no click.
Maybe before you clicked it and then another time you didn't?
Thats why not so aggressive?
Offline heavyd
  • -Receive: 29
Re: DSG Kickdown
« Reply #7 on: January 26, 2011, 10:34:05 am »
I never knew that :happy2: I should learn to read manuals :laugh:
