Author Topic: Help needed coding rns510 and highline  (Read 5404 times)
Offline PDT
  • -Receive: 142
« on: February 04, 2011, 06:33:20 pm »
Fitted my RNS510 today, all works except 2 things:
On mfsw the up/down buttons dont cycle through stations or tracks
The highline doesnt show any nav or audio options.
Volume, mute etc on the mfsw work perfectly. Any ideas?
Offline 182_blue
  • -Receive: 54
Re: Help needed coding rns510 and highline
« Reply #1 on: February 04, 2011, 06:41:45 pm »
What coding have you done ?
Offline PDT
  • -Receive: 142
« Reply #2 on: February 04, 2011, 07:00:57 pm »
Nothing yet :laugh:
Offline 182_blue
  • -Receive: 54
« Reply #3 on: February 04, 2011, 07:16:48 pm »
That will be the problem then :laugh:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: February 04, 2011, 08:20:29 pm »
......... and you expect people to trust you to flash their ECU  :stupid:
 :evilgrin:
Stu...
« Reply #5 on: February 04, 2011, 08:48:00 pm »
 :evilgrin:
:notworthy:  :signLOL:
Offline kevinm
  • -Receive: 25
  • No. 728
« Reply #6 on: February 04, 2011, 08:51:51 pm »
After I coded the RNS510, I had to reboot it to show up on the highline.
Offline PDT
  • -Receive: 142
« Reply #7 on: February 04, 2011, 10:44:32 pm »
 :evilgrin:
I can code, repair and clone most O.E ECU's, fit aftermarket engine management, I have even built many custom made aftermarket ECU systems and we are busy working on some mapping for a car thats in this years BTCC, so ECU mapping isnt a problem.
However getting my highline system working again is baffling me :booty:
« Reply #8 on: February 04, 2011, 10:59:37 pm »
Have you enabled Navigation in the installations list.
Offline PDT
  • -Receive: 142
« Reply #9 on: February 04, 2011, 11:00:55 pm »
Not done anything yet, will maybe have a go tomorrow if I get 5 mins. Where will I find the installations list in vcds?
« Reply #10 on: February 04, 2011, 11:04:52 pm »
Open VCDS, click on 19 Can Gateway, and select the installation button. That should throw up a list of installed features, and youll need to click number 37 - Navigation
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #11 on: February 04, 2011, 11:06:50 pm »
Go into block 19 - Can-Gateway and tick 37 - Navigation
Once that is done you then need to go into block 37 - Navigation and code it to get it to work with highline.
Hardly rocket science and I haven't done any ECU coding for cars in the BTCC or anything else for that matter :booty:
Offline PDT
  • -Receive: 142
« Reply #12 on: February 04, 2011, 11:17:43 pm »
Thanks richwig  :congrats:
Carl, he beat you to it  :P
 :love:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #13 on: February 04, 2011, 11:22:11 pm »
My explanation was better though as i reminded you to code the RNS too.
I'm branching out in to Mapping now. If you can map cars but not know how to use VCDS then I will sh*t hot at mapping as i can use VCDS  :laugh: :booty:
« Reply #14 on: February 04, 2011, 11:26:21 pm »
 :grin:
