Author Topic: What boost presure?  (Read 1707 times)
Offline Jaywoo-GTI
  • -Given: 38
What boost presure?
« on: March 02, 2011, 09:24:50 am »
Just a little question for everyone out there who monitors there boost.
What PSI are you seeing and are you remaped or stock,
Ill go first,
All figure below are approx
Revo stock mode,
Peak boost -14psi
Hold boost -9psi
Revo Stage 1 mode
Peak Boost -20psi
Hold boost -16psi
Reason i ask is to see if revo stock mode runs a similar boost level to a standard car because the boost seems quite high to me.
Offline Jaywoo-GTI
  • -Given: 38
Re: What boost presure?
« Reply #1 on: March 03, 2011, 01:21:18 pm »
Anyone?
Offline Sie
« Reply #2 on: March 03, 2011, 08:27:39 pm »
I have a boost gauge and am running standard, usually 10psi with peak to 12-13psi. HTH
Sie
Fettled Laser Blue '05 GTi 5dr
Offline SteveS
« Reply #3 on: March 03, 2011, 08:33:15 pm »
my revo stage2+ sees around 20psi. my previous on stage2 seems to go upto 23ish, :(
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
h4rdy
« Reply #4 on: March 03, 2011, 10:31:20 pm »
If you had, for example, an SPS where you can change the settings. What would the boost setting be on a 2+ car to get it to have the performance of a REVO 1 car?
So if potentially 2+ is 23psi, 1 is 20 and Stock is approx 15 that would equate to B9 for 2+, B0 for Stock and around B5/6 for Stage 1?
Is there a chart for B settings and targetted boost?
The reason?
Atmospheric Conditions i.e the weather!!!
« Reply #5 on: March 03, 2011, 10:36:25 pm »
I'm running Revo2 and have a boost gauge. I'll try to remember to check and report for you when I next use my car (Sunday).
