Author Topic: Hill start with DSG  (Read 17730 times)
Offline jamma
Hill start with DSG
« on: March 07, 2011, 06:06:59 pm »
How do people hill start with DSG? I noticed today even though I was in drive the car still rolls back, is it just a case of holding onto the handbrake ?
thanks
Offline B3n
  • -Receive: 29
  • Boom!!!!
Re: Hill start with DSG
« Reply #1 on: March 07, 2011, 06:09:59 pm »
Left foot holding the brake whilst accelerating away with the right foot :happy2:
Offline jamma
« Reply #2 on: March 07, 2011, 06:15:29 pm »
haha yeah right. Spose I will have to use the handbrake.
Offline alexperkins
  • -Receive: 99
« Reply #3 on: March 07, 2011, 06:25:27 pm »
Just quickly move your foot from the brake to the accelerator  :happy2:
Offline 182_blue
  • -Receive: 54
« Reply #4 on: March 07, 2011, 06:25:58 pm »
Is it supposed to roll back ?, mine has auto hill hold so never noticed it ?
Offline alexperkins
  • -Receive: 99
« Reply #5 on: March 07, 2011, 06:27:02 pm »
Some early DSG boxes didnt have hill hold on them from what I read the other day
Offline jamma
« Reply #6 on: March 07, 2011, 06:29:00 pm »
Thanks, I could use my leg I spose lol
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #7 on: March 07, 2011, 06:44:17 pm »
Is hill hold something that can be retrofitted with the right controller?  As far as I understand it its just software that holds the brakes on until the clutch is lifted ... DSG would be slightly different I guess...
Sepang Blue S4 BE Avant
Offline alexperkins
  • -Receive: 99
« Reply #8 on: March 07, 2011, 06:47:04 pm »
Works the same principle - applies the brakes until you start moving forward, though only holds a few seconds.
« Reply #9 on: March 07, 2011, 07:16:11 pm »
The oem Hill Assist, or whatever it's called, will only work on inclines which aren't steeper than a certain angle. It's not the angle which is measured but more the extra effort required by the engine at idle to move the weight of the car and its load forwards.
« Last Edit: March 07, 2011, 07:18:22 pm by RedRobin »
Offline stu_no_1
« Reply #10 on: March 07, 2011, 09:54:23 pm »
i find most hills my car starts to creep as soon as i lift the brake, but on steeper hills it can roll back a little like a delay to when the car starts creeping.  I usually just put my foot on the accelerator quickly but you can keep the handbrake on, lift your foot of the brake till it gets the bite, you should feel it trying to pull away then let handbrake go with no roll back hope that helps
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #11 on: March 08, 2011, 09:16:30 pm »
Whats so funny about that??? I wasnt joking :confused:
Offline Truckie
    • Formula Hot Laps
« Reply #12 on: March 08, 2011, 09:30:25 pm »
Left foot on the brake all the way for me. It rolls back on some hills and not on others as said in previous posts. It sometimes makes you look a  :booty:
Offline edd666999
  • -Receive: 89
« Reply #13 on: March 08, 2011, 09:30:41 pm »
the dsg prevents you from using both pedals at once, so it would only be the same as pressing the accelerator quickly after removing your foot of the brake.
The manual tells you to treat it as a manual so, use the handbrake.
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #14 on: March 08, 2011, 09:59:17 pm »
Does it?? how does the launch control work then??
I've never experianced a problem doing it the way I said. Sit on the hill with my left foot on the brake then when I need to pull off press the accelerator then take your foot off the brake :happy2: It may be a lil bit jumpy at first but you soon get the hang of it
« Last Edit: March 08, 2011, 10:02:04 pm by B3n »
