Author Topic: Hidden highline menu's  (Read 10028 times)
Offline Phil Miller
  • -Given: 86
« on: March 20, 2011, 11:35:32 am »
Hi all yesterday Lee (apollo13) fitted and coded my GTI highline cluster, now i love it to bits and looks smart as, the up and down buttons change the trip and mpg but doesnt change the song track up and down, my OH's 57 tdi does is there a hidden menu i need to go into to activate it? also on my MFD2 headunit it just says the station mhz number rather than the station name, is there a way to make it read the name rather than numbers? any help would be great  :happy2:
2004 Golf 5dr TDI, 140 remap, GTI front bumper, skirts, highline cluster, 18in wheels, jamax coilovers, winter pack
WANTED HIGHLINE CCM AND CECM PLEASE PM ME IF YOU CAN HELP
Re: Hidden highline menu's
« Reply #1 on: March 20, 2011, 12:55:19 pm »
Did you go into the audio menu before trying to change tracks?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: March 20, 2011, 02:08:05 pm »
Hi
The issue here is down to the very early version of MFD2 that you have. It will require coding to say there is a mfsw. It still may not work as the early mfsw had a different button set up.
Cluster and Key coding
Location Great Yarmouth
Offline Phil Miller
  • -Given: 86
« Reply #3 on: March 20, 2011, 03:13:29 pm »
Thanks for the info, it was all coded my cluster is a 972 and MFSW is the later type with the mute and phone button (neither do anything tho) my OH's highline allows you to set the lengh of time the lights stay on after switch off and how bright the puddle lights are but i cant find it on mine just wondered if theres a hidden menu i have to activate to adjust them all just seems strange i can use the up and down buttons for the trip but not the track
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: March 20, 2011, 03:39:31 pm »
The Audio issue is with the old mfd2, if you were to fit a newer version that would solve the audio issue.
As for the Lights and Vision that should work unless it has been coded to stay hidden in the CECM (09)
Convenience options like locking and rain closing would require a MAX CCM (46)
Offline apollo13
  • -Receive: 47
« Reply #5 on: March 20, 2011, 07:07:01 pm »
Ed its the early MFD2 for sure.
Phil, you have auto wipers and lights but did you have fogs as standard?? I was surprised the SE model only came with a lowline cluster......
« Last Edit: March 20, 2011, 07:10:16 pm by apollo13 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: March 20, 2011, 07:20:37 pm »
I saw it in the members ride, I'm sure it due to the age of the mfd2. When I did a MFSW retrofit to another 2004 car it had a mfd2 from the factory and I couldn't get the audio menu. The odd thing was that it had a highline from the factory but had a standard CCM so no convenience option.
having a Low CECM wouldn't rule out the lights and vision option, probably is coded to inactive in the long coding.
Offline apollo13
  • -Receive: 47
« Reply #7 on: March 20, 2011, 07:40:34 pm »
To be honest I did'nt even check for the lights and vision menu, it was a bit hurried as I had to get to work.
Mostly due to a poorly fitted hands free kit (not by Phil).
The live feed cable got chewed up in the steering column adjustment mechanism, blowing the cluster fuse  :fighting:
Offline Phil Miller
  • -Given: 86
« Reply #8 on: March 20, 2011, 08:06:46 pm »
Thanks lads, i hadnt thought about the MFD tbh mine doesnt have front fogs but does have auto lights and wipers, i moved that handsfree wire today and there is a mark on the metal case near the column (i would think when the wire cut thro) is the lights part something i could do with VCDS or does it need something more powerful? if it is could someone point me in the right direction please
Lee i was gonna call but after all the hassel yesterday with the steering light and cluster fuse i didnt want to hassel you, one things for sure if it is down to the MFD that gives me the perfect reason to give the OH for upgrading to the 510 ideal
Offline Phil Miller
  • -Given: 86
« Reply #9 on: March 20, 2011, 08:12:57 pm »
I was looking at the old cluster that night and it has the vw sticker on it with part number and build date and seems it must have had a replacement as the cluster is 2006 yet mine is a may 04 car
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: March 20, 2011, 08:20:16 pm »
Vag com will be rquired to check the long coding for the lights and vision.
Buy the RNS510 and the audio menu should turn up when you press the menu button
Offline apollo13
  • -Receive: 47
« Reply #11 on: March 20, 2011, 08:20:34 pm »
Yes mate the missing audio menu is due to the old MFD2, so a newer MFD2 or RNS510 is in order  :party:
The lights and vision can be activated with VCDS, Cent Electronics 09.
Thats ok mate call when you want  :happy2:
JINX  :rolleye:
Offline Phil Miller
  • -Given: 86
« Reply #12 on: March 20, 2011, 08:28:08 pm »
I had a look at Lee's yesterday and want one, i have been looking on ebay but a few things confuse me, now there is the battery drain issue (Lee did explain about the can gateway) the bluetooth side of it aswell, now being a bit of a newbie to it id need a part number to search for to get the correct can gateway and any other parts id need, i can get the use of VCDS to look at long coding, what should i be looking for? here are some of the log i saved last scan i done
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
 Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000621926
   Coding: E48B8F0600041800001400001400000000
   Shop #: WSC 00000 000 00000
   VCID: 3FA38D37170F
 Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 00000
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 260010431806DB
   Coding: 3D0F0B48070003
   Shop #: WSC 01279 785 00200
   VCID: 27733557EF9F
now at the moment i dont really understand the numbers lol what can gateway have i got and what ccm is it? if that makes sence
Offline Phil Miller
  • -Given: 86
« Reply #13 on: March 20, 2011, 08:41:24 pm »
JINX  :rolleye:
Thank you Lee i will pick the lead up at some point and give you a call, is there a list of parts and part numbers of things id need to get to fit a 510?
Offline apollo13
  • -Receive: 47
« Reply #14 on: March 20, 2011, 08:44:33 pm »
Phil all you need for the RNS retro is the unit itself plus a new gateway revision L or newer. Your current gateway is a C revision.
You can getaway without a new gateway but you will have to run a modified FW to stop the battery drain.
