Author Topic: Fitting Head unit  (Read 4113 times)
Offline Johnny_tro
Fitting Head unit
« on: March 22, 2011, 04:21:48 pm »
tried fitting my RNS510 today, all seems OK but do need to advise......
I have two small metal clips which have fallen off I can't see where there have come from.....
and MORE ANNOYING.......as picture below where the top and bottom parts fit together there is a gap which is peeing me off. Removed refitted removed refitted!! Still the same
Help
'VANDALISED' MK5 GT :( - RNS510 H, Bluetooth Armrest, MDI, 50gb hard drive, I can't park  sensors, Cruise Control, Highline Display, MFSW, Heated Seats, Remote Aux Heating System (Heats and Vents) Winter Pack, Heated & Folding Mirrors, Puddle Lights, Xenons, Headlamp Washers, Heated Washers, Auto lights and wipers, LED's, GTI brakes,, black R32 roof lining, Scirocco Rear View, Rear Footwell Lights
Offline alexperkins
  • -Receive: 99
Re: Fitting Head unit
« Reply #1 on: March 22, 2011, 04:23:10 pm »
The clips will be from the back of the fascia which goes around the RNS and AC controls
The top section needs to be pushed down as it clicks into place - you need to get the vent lined up properly so it sits back in flat.
Offline Johnny_tro
« Reply #2 on: March 22, 2011, 04:33:33 pm »
The clips will be from the back of the fascia which goes around the RNS and AC controls <<< Checked these they are all there  :ashamed:
They are like a U shapped metal clip
 as it clicks into place << You know where the two screws are that you take out to remove the lower facia......this is where the gap is. Should it CLICK/SNAP into place at these points? or at that little bit that sits above the head unit as above?
Offline alexperkins
  • -Receive: 99
« Reply #3 on: March 22, 2011, 04:36:05 pm »
It snaps in below the screws ie into the fascia plate itself
Have you got a snap of the clips? I only had one of these off the other day
Offline chowgar
« Reply #4 on: March 22, 2011, 04:41:31 pm »
you may need to add a few more pics... no gaps when I took mine apart....
Offline Johnny_tro
« Reply #5 on: March 22, 2011, 04:42:15 pm »
how do you mean? its not clicking at all.
Offline alexperkins
  • -Receive: 99
« Reply #6 on: March 22, 2011, 04:51:45 pm »
Try fit it, and take a picture of it and post it up
Need to  see where your going wrong  :happy2:
Offline Johnny_tro
« Reply #7 on: March 22, 2011, 05:38:08 pm »
This is the fitting........driving me mad!!!!!!!!!!!!!
These are the spare clips ?? there defo not off the back of the ac surround....checked. HELP lol
Offline alexperkins
  • -Receive: 99
« Reply #8 on: March 22, 2011, 06:20:37 pm »
Push down firmly on the top cover and it will snap into place
As for the clips, they might be from where the fasia clips into as this has a variety of clips on it
Offline AlanD
« Reply #9 on: March 22, 2011, 06:39:44 pm »
Yep, they do indeed look like one of the many clips that go around the fascia.
If it doesnt clip into place "apply more force", works every time.
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #10 on: March 22, 2011, 06:54:03 pm »
Where are you located, I'm sure someone local could help for 10 mins...
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline roamer1711
« Reply #11 on: March 22, 2011, 07:31:18 pm »
top vent panel has plastic spade looking ends at the front both sides, locate  these into the front first and then drop the back end in(nearest the windscreen) its acts almost like a hinge.
Went in for a Landy came out with a GTI, mid life crysis? me :-)
Offline Johnny_tro
« Reply #12 on: March 22, 2011, 08:31:03 pm »
Sorry for the poor effort.....but this may help
Should the surround CLIP/SNAP into place in position A, B, or C?
and an important note......the yellow line where I have run the thin GPS cable from the RNS.....is this how you guys have done it? could this be the problem? as it didn't seem the get in the way?
[img]http://images44.fotki.com/v1467/photos/3/866973/9356777/Example-vi.jpgimg]
Offline alexperkins
  • -Receive: 99
« Reply #13 on: March 22, 2011, 08:32:10 pm »
Offline alexperkins
  • -Receive: 99
« Reply #14 on: March 22, 2011, 08:33:08 pm »
A on the picture
Ah the cable is probably getting caught. Run it up the back, storing all the excess behind and locate it under the top vent
